[postgis-tickets] [PostGIS] #3031: "POINT EMPTY" as WKB defaults to "MULTIPOINT EMPTY" when restoring with copy and failing validation
PostGIS trac at osgeo.org
Fri Mar 20 08:35:10 PDT 2015
  Reporter:  jeanchristophesaville  |       Owner:  pramsey
      Type:  defect                 |      Status:  closed
  Priority:  medium                 |   Milestone:  PostGIS 2.1.6
 Component:  postgis                |     Version:  2.1.x
Resolution:  fixed                  |    Keywords:  POINT EMPTY , MULTIPOINT EMPTY
Changes (by pramsey):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Committed to trunk at r13372. All up-to-date. Should patch 2.0 also, I
 suppose? (same problem)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3031#comment:28>
