[postgis-tickets] [PostGIS] #3089: [RASTER] regress tests on 'loader' fail
PostGIS trac at osgeo.org
Tue Mar 24 21:36:02 PDT 2015
  Reporter:  kain     |       Owner:  dustymugs
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.1.7
 Component:  raster   |     Version:  2.1.x
Resolution:  invalid  |    Keywords:
Comment(by robe):
 kain,
 I think the reason regular PosttGIS/loader doesn't have the same issue is
 because as I recall it's a pure C library and doesn't rely on GEOS (which
 is C++).  Anyway glad to see you were able to find a workaround. As a
 general rule, I try to avoid compiling GDAL with geos.  Creates a big mess
 also when you try to upgrade GEOS without recompiling GDAL (from what I
 remember -- I think pramsey has experienced that unpleasantness to)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3089#comment:4>
