[postgis-tickets] [PostGIS] #3089: [RASTER] regress tests on 'loader' fail
PostGIS trac at osgeo.org
Tue Mar 24 22:25:33 PDT 2015
  Reporter:  kain     |       Owner:  dustymugs
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.1.7
 Component:  raster   |     Version:  2.1.x
Resolution:  invalid  |    Keywords:
Comment(by kain):
 Replying to [comment:4 robe]:
 > kain,
 > I think the reason regular PosttGIS/loader doesn't have the same issue
 is because as I recall it's a pure C library and doesn't rely on GEOS
 (which is C++).  Anyway glad to see you were able to find a workaround. As
 a general rule, I try to avoid compiling GDAL with geos.  Creates a big
 mess also when you try to upgrade GEOS without recompiling GDAL (from what
 I remember -- I think pramsey has experienced that unpleasantness to)
 Thanks Robe, you are right, PostGIS/loader is pure C library, they are
 different. I'm discussing with our releng engineers to find a general way
 to compile GDAL and GEOS across multiple platforms.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3089#comment:5>
