[postgis-tickets] [PostGIS] #3321: Performance regression in topology load
trac at osgeo.org
Wed Oct 7 11:00:21 PDT 2015
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: topology | Version: trunk
Resolution: | Keywords:
Comment (by strk):
Confirmed:
-- limit 20k offset 0 real 7m27.072s [2.2.0dev]
-- limit 20k offset 0 real 3m11.396s [2.1.9dev]
-- Query:
SELECT DropTopology('million_poly_topo1');
SELECT CreateTopology('million_poly_topo1');
SELECT count(*) FROM (
SELECT TopoGeo_addPolygon('million_poly_topo1', ST_GeometryN(geom,1))
FROM ( select * from million_poly_topo1
order by gid limit 20000 offset 0
) foo
) bar;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3321#comment:1>
