[postgis-tickets] [PostGIS] #2316: Setup buildbot jobs to test sfcgal
PostGIS trac at osgeo.org
Mon Oct 26 00:54:52 PDT 2015
  Reporter:  robe       |      Owner:  robe
      Type:  task       |     Status:  new
  Priority:  high       |  Milestone:  Management 2.0
 Component:  buildbots  |    Version:  trunk
Resolution:             |   Keywords:
Comment (by robe):
 I think it might be I don't have enough memory in debbie.  Only have 2GB.
 Anyrate, I took the chicken route and installed sfcgal from packages using
 apt-get install libsfcgal-dev
 an I got sucky 1.1.0.  Maybe they'll have 1.2.0 available soon.
 I switched 2.3.0 to test with SFCGAL and it succeeded.
 I'll switch 2.2.0 to do the same and close this out.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2316#comment:11>
