[postgis-tickets] [PostGIS] #2316: Setup buildbot jobs to test sfcgal
trac at osgeo.org
Sun Oct 25 23:12:59 PDT 2015
Reporter: robe | Owner: robe
Type: task | Status: new
Priority: high | Milestone: Management 2.0
Component: buildbots | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Well I started trying to compile sfcgal on the new debbie. I installed
cgal and boost using apt-get install no problem. I figured I should
compile sfcgal to follow the updates like I do with GDAL.
Anyway it failed midway - ticketed here.
https://github.com/Oslandia/SFCGAL/issues/114
The issue might be something wrong with GCC 5.2.1 (
https://gcc.gnu.org/gcc-5/) and related to issue #3346 (which seems to be
something to do with GEOS compile). I'm not sure if any of us is running
GCC 5.2 chain besides debbie. I only have 4.8.3 running on winnie and
travis is running 4.6.3.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2316#comment:10>
