[postgis-tickets] [PostGIS] #3348: --with-sfcgal requires path to config even when config is in system path
PostGIS trac at osgeo.org
Mon Oct 26 01:25:15 PDT 2015
 Reporter:  robe    |      Owner:  colivier
     Type:  defect  |     Status:  new
 Priority:  medium  |  Milestone:  PostGIS 2.2.1
Component:  sfcgal  |    Version:  2.1.x
 Keywords:          |
 When configuring debbie to build with sfcgal, I figured since I installed
 sfcgal in system (/usr/bin)
 ./configure --with-sfgcal
 would have been sufficient.  Instead I got a compile error:
 configure: error: sfcgal-config cannot be found. Please install sfcgal
 I had to find where it got installed with:
 dpkg -L libsfcgal-dev
 and then pass in the full path
 --with-sfcgal=/usr/bin/sfcgal-configu
 Technically this is not a bug since our documentation says you have to
 pass in the full path, but would be nice for it to find it so its like
 other configure scripts.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3348>
