[postgis-tickets] [PostGIS] #3348: --with-sfcgal requires path to config even when config is in system path
PostGIS trac at osgeo.org
Mon Oct 26 01:25:55 PDT 2015
  Reporter:  robe    |      Owner:  colivier
      Type:  defect  |     Status:  new
  Priority:  medium  |  Milestone:  PostGIS 2.2.1
 Component:  sfcgal  |    Version:  2.1.x
Resolution:          |   Keywords:
Description changed by robe:
Old description:
> When configuring debbie to build with sfcgal, I figured since I installed
> sfcgal in system (/usr/bin)
> ./configure --with-sfgcal
> would have been sufficient.  Instead I got a compile error:
> configure: error: sfcgal-config cannot be found. Please install sfcgal
> I had to find where it got installed with:
> dpkg -L libsfcgal-dev
> and then pass in the full path
> --with-sfcgal=/usr/bin/sfcgal-configu
> Technically this is not a bug since our documentation says you have to
> pass in the full path, but would be nice for it to find it so its like
> other configure scripts.
New description:
 sfcgal in system (/usr/bin) installing using apt-get install from sid repo
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3348#comment:1>
