[postgis-tickets] [PostGIS] #3525: Winnie failing on 32-bit runs in raster
PostGIS trac at osgeo.org
Sat Apr 9 12:55:03 PDT 2016
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 2.2.3
Component:  buildbots  |    Version:  2.2.x
 Keywords:             |
 This just started happening rescently on 32-bit runs.  What's odd is its
 only on 2.3 (not 2.2)
 Creating database 'postgis_reg'
 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis
 Died at run_test.pl line 1278.
  failed (Error encountered creating EXTENSION POSTGIS:
 /projects/postgis/tmp/2.3.0dev_pg9.3_geos3.5.0_gdal2.0.2w32/regress_log)
 createlang: language "plpgsql" is already installed in database
 "postgis_reg"
 ERROR:  could not load library
 "e:/jenkins/postgresql/rel/pg9.3w32gcc481edb/lib/rtpostgis-2.3.dll":
 Invalid access to memory location.
 Makefile:269: recipe for target `check' failed
 make[1]: *** [check] Error 1
 make[1]: Leaving directory `/projects/postgis/branches/2.3/regress'
 GNUmakefile:16: recipe for target `check' failed
 make: *** [check] Error 1
 I think this has soemthign to do with my GDAL 2.0.2 compile (+ with new
 curl)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3525>
