[postgis-tickets] [PostGIS] #3524: ST_Distance for geography should be cancellable
PostGIS trac at osgeo.org
Tue Apr 12 12:23:16 PDT 2016
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  high     |  Milestone:  PostGIS 2.1.9
 Component:  postgis  |    Version:  2.2.x
Resolution:  fixed    |   Keywords:
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 OK, in 2.2 (r14821) and trunk (r14821) the brute force calculation is now
 interruptible. For 2.1, I could not easily add it, as the interruption
 framework for liblwgeom only dates to 2.2+. Not sure how critical this is
 considered in that regard. See #3528 for follow-on work.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3524#comment:8>
