[postgis-tickets] [PostGIS] #3530: geocode_intersection fails to find Cumming / Seaman in NY
PostGIS trac at osgeo.org
Sun Apr 17 13:01:42 PDT 2016
  Reporter:  robe            |      Owner:  robe
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 2.2.3
 Component:  tiger geocoder  |    Version:  2.2.x
Resolution:                  |   Keywords:
Comment (by robe):
 phew figured out the issue.  It's because the tiger data ST_Intersects
 between the two edges returns false, however I also do a node id check, so
 I'm thinking of just keeping the node id check and chucking the Intersects
 check.  I think it ends up being faster anyway.  Will have to do some
 tests to confirm.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3530#comment:2>
