[postgis-tickets] r14846 - revise to use node start/end of edges for geocode_intersection and remove ST_Intersects check
Regina Obe
lr at pcorp.us
Sun Apr 17 13:19:00 PDT 2016
Author: robe
Date: 2016-04-17 13:19:00 -0700 (Sun, 17 Apr 2016)
New Revision: 14846
trunk/extras/tiger_geocoder/geocode/geocode_intersection.sql
references #3530 for postgis 2.3 (trunk)
Modified: trunk/extras/tiger_geocoder/geocode/geocode_intersection.sql
--- trunk/extras/tiger_geocoder/geocode/geocode_intersection.sql 2016-04-14 00:17:17 UTC (rev 14845)
+++ trunk/extras/tiger_geocoder/geocode/geocode_intersection.sql 2016-04-17 20:19:00 UTC (rev 14846)
@@ -8,11 +8,18 @@
-- Use case example an address at the intersection of 2 streets:
-- SELECT pprint_addy(addy), st_astext(geomout),rating FROM geocode_intersection('School St', 'Washington St', 'MA', 'Boston','02117');
--DROP FUNCTION tiger.geocode_intersection(text,text,text,text,text,integer);
-CREATE OR REPLACE FUNCTION geocode_intersection(IN roadway1 text, IN roadway2 text, IN in_state text, IN in_city text DEFAULT '', IN in_zip text DEFAULT '',
-IN num_results integer DEFAULT 10, OUT ADDY NORM_ADDY,
- OUT GEOMOUT GEOMETRY,
- OUT RATING INTEGER) RETURNS SETOF record AS
+CREATE OR REPLACE FUNCTION geocode_intersection(
+ IN roadway1 text,
+ IN roadway2 text,
+ IN in_state text,
+ IN in_city text DEFAULT ''::text,
+ IN in_zip text DEFAULT ''::text,
+ IN num_results integer DEFAULT 10,
+ OUT addy norm_addy,
+ OUT geomout geometry,
+ OUT rating integer)
+ RETURNS SETOF record AS
+$BODY$
DECLARE
var_na_road norm_addy;
var_na_inter1 norm_addy;
@@ -51,7 +58,7 @@
FROM (SELECT * FROM tiger.featnames
WHERE statefp = $1 AND ( lower(name) = $2 ' ||
CASE WHEN length(var_na_road.streetName) > 5 THEN ' or lower(fullname) LIKE $6 || ''%'' ' ELSE '' END || ')'
- || ') AS f LEFT JOIN (SELECT * FROM addr WHERE addr.statefp = $1) As addr ON (addr.tlid = f.tlid AND addr.statefp = f.statefp)
+ || ') AS f LEFT JOIN (SELECT * FROM tiger.addr As addr WHERE addr.statefp = $1) As addr ON (addr.tlid = f.tlid AND addr.statefp = f.statefp)
WHERE $5::text[] IS NULL OR addr.zip = ANY($5::text[]) OR addr.zip IS NULL
ORDER BY CASE WHEN lower(f.fullname) = $6 THEN 0 ELSE 1 END
LIMIT 50000
@@ -60,7 +67,7 @@
WHERE statefp = $1 AND ( lower(name) = $4 ' ||
CASE WHEN length(var_na_inter1.streetName) > 5 THEN ' or lower(fullname) LIKE $7 || ''%'' ' ELSE '' END || ')'
- || ' ) AS f LEFT JOIN (SELECT * FROM tiger.addr AS addr WHERE addr.statefp = $1) AS addr ON (addr.tlid = f.tlid AND addr.statefp = f.statefp)
+ || ' ) AS f LEFT JOIN (SELECT * FROM addr WHERE addr.statefp = $1) AS addr ON (addr.tlid = f.tlid AND addr.statefp = f.statefp)
WHERE $5::text[] IS NULL OR addr.zip = ANY($5::text[]) or addr.zip IS NULL
ORDER BY CASE WHEN lower(f.fullname) = $7 THEN 0 ELSE 1 END
LIMIT 50000
@@ -75,7 +82,7 @@
e2 AS (SELECT e.the_geom, e.tnidf, e.tnidt, a.*,
CASE WHEN a.side = ''L'' THEN e.tfidl ELSE e.tfidr END AS tfid
FROM (SELECT * FROM tiger.edges WHERE statefp = $1) AS e INNER JOIN a2 AS a ON (e.statefp = a.statefp AND a.tlid = e.tlid)
- INNER JOIN e1 ON (e.statefp = e1.statefp AND ST_Intersects(e.the_geom, e1.the_geom)
+ INNER JOIN e1 ON (e.statefp = e1.statefp
AND ARRAY[e.tnidf, e.tnidt] && ARRAY[e1.tnidf, e1.tnidt] )
WHERE (lower(e.fullname) = $7 or lower(a.name) LIKE $4 || ''%'')
@@ -100,7 +107,7 @@
AS a_rating
FROM e1
INNER JOIN e2 ON (
- ST_Intersects(e1.the_geom, e2.the_geom) )
+ ARRAY[e2.tnidf, e2.tnidt] && ARRAY[e1.tnidf, e1.tnidt] )
INNER JOIN (SELECT * FROM tiger.faces WHERE statefp = $1) As fa1 ON (e1.tfid = fa1.tfid )
LEFT JOIN tiger.place AS p ON (fa1.placefp = p.placefp AND p.statefp = $1 )
ORDER BY e1.tlid, e1.side, a_rating LIMIT $9*4 )
@@ -141,8 +148,8 @@
END LOOP;
RETURN;
END;
+$BODY$
LANGUAGE plpgsql IMMUTABLE
COST 1000
ROWS 10;
-ALTER FUNCTION geocode_intersection(IN text, IN text, IN text, IN text, IN text, IN integer) SET join_collapse_limit='2';
+ALTER FUNCTION geocode_intersection(text, text, text, text, text, integer) SET join_collapse_limit='2';
