[postgis-tickets] [PostGIS] #3607: ST_LocateBetweenElevations failing on typed collections
trac at osgeo.org
Fri Aug 5 06:38:23 PDT 2016
Reporter: komzpa | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.3.0
Component: postgis | Version: 2.2.x
Resolution: | Keywords:
Changes (by strk):
* priority: medium => high
Comment:
Could you please also add a testcase in regress_lrs{.sql,expected} ? You
can reference this ticket by number in the test description (first value
returned by query) see examples in tickets.sql
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3607#comment:2>
