[postgis-tickets] [PostGIS] #3608: Shp2pgsql invalid free when -W UTF-8
trac at osgeo.org
Fri Aug 5 06:52:24 PDT 2016
Reporter: mattzen | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.0
Component: postgis | Version: 2.2.x
Keywords: |
Shp2pgsql crashes with an invalid free when passed a `-W UTF-8` argument
on the command line and the shapefile contains a code page. This is
because shp2pgsql assumes that if the `encoding` is the string `UTF-8`
then the user has not overridden it. If the code page exists in the
shapefile, the previous value of `encoding` is freed and, if it came from
a command line argument, it is not heap-allocated.
The patch in https://github.com/postgis/postgis/pull/111 prevents the
crash by `strdup`ing the command line argument, but doesn't address the
wider issue of distinguishing a user-provided "UTF-8" from a default-
supplied "UTF-8".
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3608>
