[postgis-tickets] [PostGIS] #3608: Shp2pgsql invalid free when -W UTF-8
trac at osgeo.org
Fri Aug 5 07:51:21 PDT 2016
Reporter: mattzen | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.3
Component: postgis | Version: 2.2.x
Resolution: | Keywords:
Comment (by strk):
Figured: the issue of distinguishing a user-provided from a default-
supplied is unrelated to the crash. So I will committed your patch and
invite you to file another ticket for that separate issue (which for the
record affects using or not the shapefile-provided CodePage, in shp2pgsql-
core.c:870)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3608#comment:4>
