[postgis-tickets] [PostGIS] #3451: Schema-qualify table names to avoid search path confusion or "column does not exist" error
PostGIS trac at osgeo.org
Fri Aug 5 13:02:39 PDT 2016
not exist" error
  Reporter:  mst         |      Owner:  robe
      Type:  defect      |     Status:  closed
  Priority:  critical    |  Milestone:  PostGIS 2.2.3
 Component:  tiger       |    Version:  2.2.x
  geocoder               |   Keywords:  table name, column does not exist,
Resolution:  fixed       |  schema
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 I think I took care of most of these  at least important ones.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3451#comment:7>
