[postgis-tickets] [PostGIS] #3609: debbie crashing on PostgreSQL 9.6 builds
trac at osgeo.org
Sat Aug 6 21:46:56 PDT 2016
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.3.0
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords: postgresql 9.6
Comment (by robe):
I built latest postgresql git branch under mingw and was also able to
achieve a crash.
Log shows this:
DETAIL: Failed process was running: CREATE OR REPLACE VIEW
geography_columns AS
SELECT
current_database() AS f_table_catalog,
n.nspname AS f_table_schema,
c.relname AS f_table_name,
a.attname AS f_geography_column,
postgis_typmod_dims(a.atttypmod) AS
coord_dimension,
postgis_typmod_srid(a.atttypmod) AS srid,
postgis_typmod_type(a.atttypmod) AS type
FROM
pg_class c,
pg_attribute a,
pg_type t,
pg_namespace n
WHERE t.typname = 'geography'
AND a.attisdropped = false
AND a.atttypid = t.oid
AND a.attrelid = c.oid
AND c.relnamespace = n.oid
AND NOT pg_is_other_temp_schema(c.relnamespace)
AND has_table_privilege( c.oid, 'SELECT'::text );
HINT: See C include file "ntstatus.h" for a description of the
hexadecimal value.
LOG: terminating any other active server processes
WARNING: terminating connection because of crash of another server
process
DETAIL: The postmaster has commanded this server process to roll back the
current transaction and exit, because another server process exited
abnormally and possibly corrupted shared memory.
What's interesting is that the crash doesn't happen if installing via
extension. Only old fashioned make check triggers this
-- so this works
make check RUNTESTFLAGS=--extension
-- so this crashes
make check
I think the culprit might be:
Prevent "snapshot too old" from trying to return pruned TOAST tuples.
(Commit 3e2f3c2e423b3ae906668c186bac79522b8e3e29 by rhaas)
Because the earlier likely cause Tom Lane's commit (run that included that
was successful). Might have been a fluke which is why I haven't ruled
that out.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3609#comment:4>
