[postgis-tickets] [PostGIS] #3612: ST_ClusterDBSCAN garden crasher
PostGIS trac at osgeo.org
Tue Aug 16 20:04:42 PDT 2016
  Reporter:  robe      |      Owner:  robe
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS 2.3.0
 Component:  postgis   |    Version:  trunk
Resolution:            |   Keywords:
Changes (by robe):
 * priority:  blocker => critical
Comment:
 This may be a windows specific issue.  I tried this example in plain old
 mingw environment so downgrading from blocker to critical.
 PostgreSQL 9.6beta4 on x86_64-w64-mingw32, compiled by gcc.exe
 (x86_64-win32-seh-rev1, Built by MinGW-W64 project) 4.8.3, 64-bit
 POSTGIS="2.3.0dev r15043" GEOS="3.5.0-CAPI-1.9.0 r4088" PROJ="Rel. 4.9.1,
 04 March 2015" GDAL="GDAL 2.1.0, released 2016/04/25" LIBXML="2.7.8"
 LIBJSON="0.12" RASTER
 and it returns:
 0
 1
 Which is a bummer since I get so much more info when it crashes under
 mingw.
 Dan if you could give it a try on your platform and see if you can trigger
 a crash.  I'm going to try next in my 9.5 and 9.4 windows instances
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3612#comment:3>
