[postgis-tickets] [PostGIS] #3614: support PostgreSQL 10.0
PostGIS trac at osgeo.org
Wed Aug 17 09:14:04 PDT 2016
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 2.4.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 Looks like PGDG branched off 9.6 so master is now 10.0.  Debbie's been
 testing master (so been testing 10.0) for past week which is why she's
 failing.
 So this raises the issue that our code can't handle a version number of
 10dev.
 Error is:
 make[1]: Entering directory
 '/var/lib/jenkins/workspace/postgis/branches/2.3/libpgcommon'
 gcc -g -O2 -I../liblwgeom
 -I/var/lib/jenkins/workspace/pg/rel/pg9.6w64/include/postgresql/server
 -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o gserialized_gist.o
 gserialized_gist.c
 In file included from gserialized_gist.c:17:0:
 ../postgis_config.h:150:42: error: missing binary operator before token
 "10develPostgreSQL"
  #define POSTGIS_PGSQL_VERSION PostgreSQL 10develPostgreSQL 10devel
 lwgeom_pg.h:142:5: note: in expansion of macro ‘POSTGIS_PGSQL_VERSION’
  #if POSTGIS_PGSQL_VERSION >= 85
 Makefile:61: recipe for target 'gserialized_gist.o' failed
 make[1]: *** [gserialized_gist.o] Error 1
 make[1]: Leaving directory
 GNUmakefile:16: recipe for target 'all' failed
 I pushed this milestone to PostGIS 2.4, since we really don't need to
 support 10.0 in 2.3, unless we release 2.4 after 10.0 and even then we
 only need to support at 2.3.something (not 2.3.0)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3614>
