[postgis-tickets] [PostGIS] #3506: build variable not defined ?
trac at osgeo.org
Thu Aug 25 21:03:35 PDT 2016
Reporter: darkblueb | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.3
Component: postgis | Version: 2.2.x
Resolution: | Keywords: autotools, make
Comment (by darkblueb):
ugh - revisited today.. same bat-server, same bat-error.. It is Ubuntu
1404 and apt.postgresql.org installed pg '''9.4''' and pg '''9.5''' both..
you know, port 5433 for the second "cluster" ..
I updated my source tree with PostGIS svn version 15045, then
PG_CONFIG=/usr/lib/postgresql/9.5/bin/pg_config ./configure
PG_CONFIG=/usr/lib/postgresql/9.5/bin/pg_config make
the error changes slightly if you omit the second PG_CONFIG and call make
alone. Its probably me, but, this is occurring reproducibly.
here is the output
$ PG_CONFIG=/usr/lib/postgresql/9.5/bin/pg_config ./configure
config.status: executing po-directories commands
PostGIS is now configured for x86_64-unknown-linux-gnu
-------------- Compiler Info -------------
C compiler: gcc -g -O2
SQL preprocessor:
-------------- Dependencies --------------
GEOS config: /usr/local/bin/geos-config
GEOS version: 3.5.1
GDAL config: /usr/local/bin/gdal-config
GDAL version: 2.1.0
PostgreSQL config: /usr/lib/postgresql/9.5/bin/pg_config
PostgreSQL version: PostgreSQL 9.5.4
PROJ4 version: 48
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.9.1
JSON-C support: yes
PCRE support: yes
PostGIS debug level: 0
Perl: /usr/bin/perl
--------------- Extensions ---------------
PostGIS Raster: enabled
PostGIS Topology: enabled
SFCGAL support: disabled
Address Standardizer support: enabled
-------- Documentation Generation --------
xsltproc: /usr/bin/xsltproc
xsl style sheets: /usr/share/xml/docbook/stylesheet/nwalsh
dblatex:
convert: /usr/bin/convert
mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
$ PG_CONFIG=/usr/lib/postgresql/9.5/bin/pg_config make
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
statement -Wendif-labels -Wmissing-format-attribute -Wformat-security
-fno-strict-aliasing -fwrapv -fexcess-precision=standard -g -g -O2
-fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-
security -I/usr/include/mit-krb5 -fPIC -pie -fno-omit-frame-pointer -fpic
-shared -o postgis-2.3.so postgis_module.o lwgeom_accum.o
lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_inout.o
lwgeom_functions_basic.o lwgeom_btree.o lwgeom_box.o lwgeom_box3d.o
lwgeom_geos.o lwgeom_backend_api.o lwgeom_geos_prepared.o
lwgeom_geos_clean.o lwgeom_geos_relatematch.o lwgeom_export.o
lwgeom_in_gml.o lwgeom_in_kml.o lwgeom_in_geohash.o lwgeom_in_geojson.o
lwgeom_in_encoded_polyline.o lwgeom_triggers.o lwgeom_dump.o
lwgeom_dumppoints.o lwgeom_functions_lrs.o lwgeom_functions_temporal.o
long_xact.o lwgeom_sqlmm.o lwgeom_rtree.o lwgeom_transform.o
lwgeom_window.o gserialized_typmod.o gserialized_gist_2d.o
gserialized_gist_nd.o brin_2d.o brin_nd.o brin_common.o
gserialized_estimate.o geography_inout.o geography_btree.o
geography_measurement.o geography_measurement_trees.o geometry_inout.o
-L/usr/lib/x86_64-linux-gnu -Wl,-Bsymbolic-functions -Wl,-z,relro
-Wl,-z,now -Wl,--as-needed -L/usr/lib/mit-krb5 -L/usr/lib/x86_64-linux-gnu
/mit-krb5 -Wl,--as-needed ../libpgcommon/libpgcommon.a
../liblwgeom/.libs/liblwgeom.a -L/usr/local/lib -lgeos_c -lproj
-ljson-c -lxml2 -Wl,--exclude-libs,ALL
I../libpgcommon postgis.sql.in | grep -v '^#' | \
/usr/bin/perl -lpe
"s'MODULE_PATHNAME'\$libdir/postgis-2.3'g;s'@extschema@\.''g" >
postgis.sql
/bin/sh: 1: I../libpgcommon: not found
/usr/bin/perl -lpe "s'MODULE_PATHNAME'\$libdir/postgis-2.3'g" >
postgis_for_extension.sql
/usr/bin/perl ../utils/create_undef.pl postgis.sql 95 >
uninstall_postgis.sql
/usr/bin/perl ../utils/postgis_proc_upgrade.pl postgis.sql UNUSED >
postgis_upgrade.sql.in
Unable to locate target new version number in postgis.sql
Makefile:189: recipe for target 'postgis_upgrade.sql.in' failed
make[1]: *** [postgis_upgrade.sql.in] Error 255
make[1]: *** Deleting file 'postgis_upgrade.sql.in'
make[1]: Leaving directory '/home/shared/srcs_i7d/postgis_trunk/postgis'
GNUmakefile:16: recipe for target 'all' failed
make: *** [all] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3506#comment:5>
