[postgis-tickets] r15047 - Format as per editorconfig
Sandro Santilli
strk at kbt.io
Sun Aug 28 09:47:59 PDT 2016
Author: strk
Date: 2016-08-28 09:47:59 -0700 (Sun, 28 Aug 2016)
New Revision: 15047
trunk/configure.ac
Modified: trunk/configure.ac
--- trunk/configure.ac 2016-08-27 22:46:30 UTC (rev 15046)
+++ trunk/configure.ac 2016-08-28 16:47:59 UTC (rev 15047)
@@ -55,13 +55,13 @@
dnl For GCC enable additional warning flags -Wall and -Wmissing-prototypes (using macro included with libtool)
dnl
WARNFLAGS=""
-AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wall], [_cv_wall], [-Wall], [], [WARNFLAGS="$WARNFLAGS -Wall"], [])
-AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wmissing-prototypes], [_cv_misprot], [-Wmissing-prototypes], [], [WARNFLAGS="$WARNFLAGS -Wmissing-prototypes"], [])
+AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wall], [_cv_wall], [-Wall], [], [WARNFLAGS="$WARNFLAGS -Wall"], [])
+AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wmissing-prototypes], [_cv_misprot], [-Wmissing-prototypes], [], [WARNFLAGS="$WARNFLAGS -Wmissing-prototypes"], [])
AC_SUBST([WARNFLAGS])
dnl
dnl For some GCC versions and platforms, floating point issues need to be
-dnl ironed out.
+dnl ironed out.
NUMERICFLAGS=""
AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -ffloat-store], [dummy_cv_ffloat_store], [-ffloat-store], [], [NUMERICFLAGS="$NUMERICFLAGS -ffloat-store"], [])
AC_SUBST([NUMERICFLAGS])
@@ -81,7 +81,7 @@
AC_SUBST([EXESUFFIX])
dnl
-dnl Version Information imported from Version.config
+dnl Version Information imported from Version.config
dnl
POSTGIS_MAJOR_VERSION=`cat Version.config | grep ^POSTGIS_MAJOR_VERSION | sed 's/[[^=]]*=\([[0-9]]\)/\1/g'`
POSTGIS_MINOR_VERSION=`cat Version.config | grep ^POSTGIS_MINOR_VERSION | sed 's/[[^=]]*=\([[0-9]]\)/\1/g'`
@@ -131,12 +131,12 @@
AC_CHECK_FUNC(asprintf, AC_DEFINE([HAVE_ASPRINTF]))
AC_FUNC_FSEEKO()
-dnl
+dnl
dnl First see if we have isfinite in basic header
dnl then check to see if it's a GNU extension
dnl
-AC_CHECK_DECL(isfinite,
- [AC_DEFINE([HAVE_ISFINITE])],
+AC_CHECK_DECL(isfinite,
+ [AC_DEFINE([HAVE_ISFINITE])],
[#include <math.h>])
@@ -147,14 +147,14 @@
AC_DEFINE([HAVE_GNU_ISFINITE]),
- #define _GNU_SOURCE
+ #define _GNU_SOURCE
#include <math.h>
-dnl
-dnl MingW requires use of pwd -W to give proper Windows (not MingW) paths
-dnl for in-place regression tests
-dnl
+dnl
+dnl MingW requires use of pwd -W to give proper Windows (not MingW) paths
+dnl for in-place regression tests
+dnl
case $host_os in
*mingw*)
MINGWBUILD=1
@@ -213,17 +213,17 @@
dnl Allow the user to specify the location of the html/docbook.xsl stylesheet
dnl
-AC_ARG_WITH([xsldir],
- [AS_HELP_STRING([--with-xsldir=PATH], [specify the directory containing the docbook.xsl stylesheet])],
+AC_ARG_WITH([xsldir],
+ [AS_HELP_STRING([--with-xsldir=PATH], [specify the directory containing the docbook.xsl stylesheet])],
[XSLBASE="$withval"], [XSLBASE=""])
XSLBASE_AUTO=""
if test "x$XSLBASE" = "x"; then
- dnl If the user did not specify a directory for the docbook
+ dnl If the user did not specify a directory for the docbook
dnl stylesheet, choose the first directory
dnl that matches from the following list
SEARCHPATH="
- /usr/share/sgml/docbook/xsl-stylesheets
+ /usr/share/sgml/docbook/xsl-stylesheets
/usr/share/xml/docbook/stylesheet/nwalsh
/usr/share/sgml/docbook/stylesheet/xsl/nwalsh
/opt/local/share/xsl/docbook-xsl
@@ -237,17 +237,17 @@
fi
done
- dnl Check to see if the automatically searched paths above located a
+ dnl Check to see if the automatically searched paths above located a
dnl valid Docbook stylesheet
if test "x$XSLBASE_AUTO" = "x"; then
AC_MSG_WARN([could not locate Docbook stylesheets required to build the documentation])
fi
else
- dnl The user specified an alternate directory so make sure everything
+ dnl The user specified an alternate directory so make sure everything
dnl looks sensible
if test ! -d "$XSLBASE"; then
AC_MSG_ERROR([the docbook stylesheet directory specified using --with-xsldir does not exist])
- fi
+ fi
if test ! -f "$XSLBASE/html/docbook.xsl"; then
AC_MSG_ERROR([the docbook stylesheet directory specified using --with-xsldir does not contain the html/docbook.xsl file])
@@ -255,9 +255,9 @@
fi
dnl
-dnl If XSLBASE has been set then at this point we know it must be
+dnl If XSLBASE has been set then at this point we know it must be
dnl valid and so we can just use it. If XSLBASE_AUTO has been set, and XSLBASE
-dnl is empty then a valid stylesheet was found in XSLBASE_AUTO so we
+dnl is empty then a valid stylesheet was found in XSLBASE_AUTO so we
dnl should use that. Otherwise just continue silently with a blank XSLBASE
dnl variable which will trigger the error message in the documentation Makefile
dnl
@@ -273,8 +273,8 @@
dnl
dnl Let's see if we can find mathml2.dtd
dnl
-AC_ARG_WITH([mathmldtd],
- [AS_HELP_STRING([--with-mathmldtd=PATH], [specify the dtd path for mathml2.dtd])],
+AC_ARG_WITH([mathmldtd],
+ [AS_HELP_STRING([--with-mathmldtd=PATH], [specify the dtd path for mathml2.dtd])],
[MATHML2_DTD="$withval"], [MATHML2_DTD=""])
dnl TODO: get more paths to add here...
if test "x$MATHML2_DTD" = "x"; then
@@ -294,9 +294,9 @@
dnl ===========================================================================
dnl Detect CUnit if it is installed (used for unit testing)
dnl
-dnl Note that we pass any specified CPPFLAGS and LDFLAGS into the Makefile
-dnl as CUnit is the only compile-time dependency that cannot obtain any
-dnl specialised flags using a --with-X parameter, and so we allow this
+dnl Note that we pass any specified CPPFLAGS and LDFLAGS into the Makefile
+dnl as CUnit is the only compile-time dependency that cannot obtain any
+dnl specialised flags using a --with-X parameter, and so we allow this
dnl information to be passed in if required.
@@ -308,21 +308,21 @@
AC_MSG_WARN([could not locate CUnit required for unit tests])
AC_SUBST([CUNIT_CPPFLAGS])
AC_SUBST([CUNIT_LDFLAGS])
-dnl Detect iconv if it is installed (used for shp2pgsql encoding conversion
+dnl Detect iconv if it is installed (used for shp2pgsql encoding conversion
dnl if available)
ICONV_CFLAGS=""
ICONV_LDFLAGS=""
-AC_ARG_WITH([libiconv],
- [AS_HELP_STRING([--with-libiconv=PATH], [specify a path to non-default libiconv installation])],
+AC_ARG_WITH([libiconv],
+ [AS_HELP_STRING([--with-libiconv=PATH], [specify a path to non-default libiconv installation])],
[LIBICONV_PATH="$withval"], [LIBICONV_PATH=""])
LDFLAGS_SAVE="$LDFLAGS"
@@ -353,7 +353,7 @@
dnl No iconv library was found; issue a warning to the console
AC_MSG_ERROR([Could not find libiconv. Please install libiconv and libiconv-devel.])
fi
- fi
+ fi
fi
else
dnl No iconv header was found; issue a warning to the console
@@ -413,8 +413,8 @@
if test "x$LIBLWGEOM_ONLY" = "xno"; then
- dnl Ensure that $PG_CONFIG --pgxs points to a valid file. This is because some
- dnl distributions such as Debian also include pg_config as part of libpq-dev
+ dnl Ensure that $PG_CONFIG --pgxs points to a valid file. This is because some
+ dnl distributions such as Debian also include pg_config as part of libpq-dev
dnl packages, but don't install the Makefile it points to unless
dnl the postgresql-server-dev packages are installed :)
@@ -428,7 +428,7 @@
dnl Extract the version information from pg_config
dnl Note: we extract the major & minor separately, ensure they are numeric, and then combine to give
- dnl the final version. This is to guard against user error...
+ dnl the final version. This is to guard against user error...
PGSQL_MAJOR_VERSION=`$PG_CONFIG --version | sed 's/[[^0-9]]*\([[0-9]]\)\.\([[0-9]]\).*/\1/'`
PGSQL_MINOR_VERSION=`$PG_CONFIG --version | sed 's/[[^0-9]]*\([[0-9]]\)\.\([[0-9]]\).*/\2/'`
PGSQL_FULL_VERSION=`$PG_CONFIG --version`
@@ -449,7 +449,7 @@
HAVE_BRIN=yes
fi
- dnl Note: We don't need the server-side LDFLAGS or CPPFLAGS because we get these from PGXS
+ dnl Note: We don't need the server-side LDFLAGS or CPPFLAGS because we get these from PGXS
dnl Extract the linker and include flags for the frontend (for programs that use libpq)
PGSQL_FE_LDFLAGS=-L`$PG_CONFIG --libdir`" -lpq"
@@ -506,7 +506,7 @@
LIBS="$LIBS_SAVE"
- AC_DEFINE_UNQUOTED([POSTGIS_PGSQL_VERSION], [$POSTGIS_PGSQL_VERSION], [PostgreSQL server version])
+ AC_DEFINE_UNQUOTED([POSTGIS_PGSQL_VERSION], [$POSTGIS_PGSQL_VERSION], [PostgreSQL server version])
AC_SUBST([POSTGIS_PGSQL_VERSION])
AC_SUBST([HAVE_BRIN])
@@ -533,8 +533,8 @@
dnl (needed to GeomFromGML and GeomFromKML functions)
-AC_ARG_WITH([xml2config],
- [AS_HELP_STRING([--with-xml2config=FILE], [specify an alternative xml2-config file])],
+AC_ARG_WITH([xml2config],
+ [AS_HELP_STRING([--with-xml2config=FILE], [specify an alternative xml2-config file])],
[XML2CONFIG="$withval"], [XML2CONFIG=""])
if test "x$XML2CONFIG" = "x"; then
@@ -554,12 +554,12 @@
AC_MSG_RESULT([Using user-specified xml2-config file: $XML2CONFIG])
else
AC_MSG_ERROR([the user-specified xml2-config file $XML2CONFIG does not exist])
- fi
+ fi
fi
fi
-dnl Extract the linker and include flags
+dnl Extract the linker and include flags
XML2_LDFLAGS=`$XML2CONFIG --libs`
XML2_CPPFLAGS=`$XML2CONFIG --cflags`
@@ -588,8 +588,8 @@
dnl Detect the version of GEOS installed on the system
-AC_ARG_WITH([geosconfig],
- [AS_HELP_STRING([--with-geosconfig=FILE], [specify an alternative geos-config file])],
+AC_ARG_WITH([geosconfig],
+ [AS_HELP_STRING([--with-geosconfig=FILE], [specify an alternative geos-config file])],
[GEOSCONFIG="$withval"], [GEOSCONFIG=""])
if test "x$GEOSCONFIG" = "x"; then
@@ -609,19 +609,19 @@
AC_MSG_RESULT([Using user-specified geos-config file: $GEOSCONFIG])
else
AC_MSG_ERROR([the user-specified geos-config file $GEOSCONFIG does not exist])
- fi
+ fi
fi
fi
dnl Extract the version information from geos_config
-dnl Note: we extract the major & minor separately, ensure they are numeric,
-dnl and then combine to give the final version.
-dnl This is to guard against user error...
+dnl Note: we extract the major & minor separately, ensure they are numeric,
+dnl and then combine to give the final version.
+dnl This is to guard against user error...
GEOS_MAJOR_VERSION=`$GEOSCONFIG --version | cut -d. -f1 | sed 's/[[^0-9]]//g'`
GEOS_MINOR_VERSION=`$GEOSCONFIG --version | cut -d. -f2 | sed 's/[[^0-9]]//g'`
GEOS_PATCH_VERSION=`$GEOSCONFIG --version | cut -d. -f3 | sed 's/[[^0-9]]//g'`
-if test "x$GEOS_PATCH_VERSION" = "x"; then
- GEOS_PATCH_VERSION="0";
+if test "x$GEOS_PATCH_VERSION" = "x"; then
+ GEOS_PATCH_VERSION="0";
fi
GEOS_FULL_VERSION=`$GEOSCONFIG --version`
POSTGIS_GEOS_VERSION="$GEOS_MAJOR_VERSION$GEOS_MINOR_VERSION"
@@ -635,7 +635,7 @@
AC_MSG_ERROR([PostGIS requires GEOS >= 3.3.0])
fi
GEOS_LDFLAGS=`$GEOSCONFIG --ldflags`
GEOS_CPPFLAGS=-I`$GEOSCONFIG --includes`
AC_SUBST([GEOS_LDFLAGS])
@@ -656,7 +656,7 @@
LIBS="$LIBS_SAVE"
-AC_DEFINE_UNQUOTED([POSTGIS_GEOS_VERSION], [$POSTGIS_GEOS_VERSION], [GEOS library version])
+AC_DEFINE_UNQUOTED([POSTGIS_GEOS_VERSION], [$POSTGIS_GEOS_VERSION], [GEOS library version])
AC_SUBST([POSTGIS_GEOS_VERSION])
AC_SUBST([GEOS_NUMERIC_VERSION])
@@ -665,9 +665,9 @@
dnl SFCGAL library support
-AC_ARG_WITH([sfcgal],
- [AS_HELP_STRING([--with-sfcgal=PATH], [Add SFCGAL support. ARG allows to specify an alternate PATH to sfcgal-config])],
- [SFCGAL_CONFIG="$withval"],
+AC_ARG_WITH([sfcgal],
+ [AS_HELP_STRING([--with-sfcgal=PATH], [Add SFCGAL support. ARG allows to specify an alternate PATH to sfcgal-config])],
+ [SFCGAL_CONFIG="$withval"],
[with_sfcgal=auto])
HAVE_SFCGAL="no"
@@ -703,7 +703,7 @@
AC_MSG_ERROR([sfcgal-config cannot be found. Please install sfcgal])
fi
fi
-fi
+fi
AC_SUBST([SFCGAL_VERSION])
AC_SUBST([SFCGAL_CPPFLAGS])
@@ -721,8 +721,8 @@
GETTEXT_CFLAGS=""
GETTEXT_LDFLAGS=""
-AC_ARG_WITH([gettext],
- [AS_HELP_STRING([--with-gettext=PATH], [specify a path to non-default gettext installation])],
+AC_ARG_WITH([gettext],
+ [AS_HELP_STRING([--with-gettext=PATH], [specify a path to non-default gettext installation])],
[GETTEXT_PATH="$withval"], [GETTEXT_PATH="yes"])
@@ -755,23 +755,23 @@
dnl Detect the version of PROJ.4 installed
-AC_ARG_WITH([projdir],
- [AS_HELP_STRING([--with-projdir=PATH], [specify the PROJ.4 installation directory])],
+AC_ARG_WITH([projdir],
+ [AS_HELP_STRING([--with-projdir=PATH], [specify the PROJ.4 installation directory])],
[PROJDIR="$withval"], [PROJDIR=""])
if test ! "x$PROJDIR" = "x"; then
- dnl Make sure that the directory exists
+ dnl Make sure that the directory exists
if test "x$PROJDIR" = "xyes"; then
AC_MSG_ERROR([you must specify a parameter to --with-projdir, e.g. --with-projdir=/path/to])
else
if test -d "$PROJDIR"; then
AC_MSG_RESULT([Using user-specified proj directory: $PROJDIR])
- dnl Add the include directory to PROJ_CPPFLAGS
- PROJ_CPPFLAGS="-I$PROJDIR/include"
+ dnl Add the include directory to PROJ_CPPFLAGS
+ PROJ_CPPFLAGS="-I$PROJDIR/include"
PROJ_LDFLAGS="-L$PROJDIR/lib"
else
- AC_MSG_ERROR([the --with-projdir directory "$PROJDIR" cannot be found])
+ AC_MSG_ERROR([the --with-projdir directory "$PROJDIR" cannot be found])
fi
fi
fi
@@ -780,7 +780,7 @@
dnl Check that we can find the proj_api.h header file
CPPFLAGS_SAVE="$CPPFLAGS"
CPPFLAGS="$PROJ_CPPFLAGS"
-AC_CHECK_HEADER([proj_api.h], [], [AC_MSG_ERROR([could not find proj_api.h - you may need to specify the directory of a PROJ.4 installation using --with-projdir])])
+AC_CHECK_HEADER([proj_api.h], [], [AC_MSG_ERROR([could not find proj_api.h - you may need to specify the directory of a PROJ.4 installation using --with-projdir])])
dnl Return the PROJ.4 version number
AC_PROJ_VERSION([POSTGIS_PROJ_VERSION])
@@ -791,7 +791,7 @@
AC_SUBST([PROJ_CPPFLAGS])
AC_SUBST([PROJ_LDFLAGS])
-dnl Ensure that we are using PROJ >= 4.6.0 (requires pj_set_searchpath)
+dnl Ensure that we are using PROJ >= 4.6.0 (requires pj_set_searchpath)
if test ! "$POSTGIS_PROJ_VERSION" -ge 46; then
AC_MSG_ERROR([PostGIS requires PROJ >= 4.6.0])
fi
@@ -841,7 +841,7 @@
CPPFLAGS="$JSON_CPPFLAGS"
AC_CHECK_HEADER([json/json.h], [HAVE_JSON=yes], [
AC_CHECK_HEADER([json-c/json.h], [HAVE_JSON=yes; HAVE_JSON_C=yes], [])
CPPFLAGS="$CPPFLAGS_SAVE"
dnl Ensure we can link against libjson
@@ -871,13 +871,13 @@
dnl Detect GTK+2.0 for GUI
-AC_ARG_WITH([gui],
- [AS_HELP_STRING([--with-gui], [compile the data import GUI (requires GTK+2.0)])],
+AC_ARG_WITH([gui],
+ [AS_HELP_STRING([--with-gui], [compile the data import GUI (requires GTK+2.0)])],
[GUI="yes"], [GUI="no"])
if test "x$GUI" = "xyes"; then
AC_MSG_RESULT([GUI: Build requested, checking for dependencies (GKT+2.0)])
- dnl Try to find the GTK libs with pkgconfig
+ dnl Try to find the GTK libs with pkgconfig
AM_PATH_GTK_2_0([2.8.0], [GTK_BUILD="gui"], [GTK_BUILD=""])
dnl Add -mwindows to MinGW GUI build
@@ -904,11 +904,11 @@
dnl Allow the user to enable debugging with --enable-debug
dnl
-dnl Currently we default to debug level 4. See DEBUG for more information.
+dnl Currently we default to debug level 4. See DEBUG for more information.
dnl
-AC_ARG_ENABLE([debug], AC_HELP_STRING([--enable-debug], [Enable verbose debugging messages]),
- [POSTGIS_DEBUG_LEVEL=4], [POSTGIS_DEBUG_LEVEL=0])
+AC_ARG_ENABLE([debug], AC_HELP_STRING([--enable-debug], [Enable verbose debugging messages]),
+ [POSTGIS_DEBUG_LEVEL=4], [POSTGIS_DEBUG_LEVEL=0])
AC_DEFINE_UNQUOTED([POSTGIS_DEBUG_LEVEL], [$POSTGIS_DEBUG_LEVEL], [PostGIS library debug level (0=disabled)])
@@ -916,8 +916,8 @@
dnl Allow the user to enable GEOS profiling with --enable-profile
dnl
-AC_ARG_ENABLE([profile], AC_HELP_STRING([--enable-profile], [Enable GEOS profiling messages]),
- [POSTGIS_PROFILE=1], [POSTGIS_PROFILE=0])
+AC_ARG_ENABLE([profile], AC_HELP_STRING([--enable-profile], [Enable GEOS profiling messages]),
+ [POSTGIS_PROFILE=1], [POSTGIS_PROFILE=0])
AC_DEFINE_UNQUOTED([POSTGIS_PROFILE], [$POSTGIS_PROFILE], [Enable GEOS profiling (0=disabled)])
@@ -946,7 +946,7 @@
-dnl Other parameters
+dnl Other parameters
dnl
dnl Always enable BBOX caching by default
@@ -969,51 +969,51 @@
LDFLAGS="$LDFLAGS_SAVE"
CFLAGS="$CFLAGS_SAVE"
CHECK_PCRE=yes
HAVE_PCRE=no
ADDRESS_STANDARDIZER="address_standardizer"
- AC_ARG_WITH([pcredir],
- [AS_HELP_STRING([--with-pcredir=PATH], [specify the PCRE installation directory])],
+ AC_ARG_WITH([pcredir],
+ [AS_HELP_STRING([--with-pcredir=PATH], [specify the PCRE installation directory])],
[PCREDIR="$withval"], [PCREDIR=""])
if test ! "x$PCREDIR" = "x"; then
if test "x$PCREDIR" = "xyes"; then
AC_MSG_ERROR([you must specify a parameter to --with-pcredir, e.g. --with-pcredir=/path/to])
else
if test -d "$PCREDIR"; then
AC_MSG_RESULT([Using user-specified PCRE directory: $PCREDIR])
- dnl Add the include directory to PCRE_CPPFLAGS
- PCRE_CPPFLAGS="-I$PCREDIR/include"
+ dnl Add the include directory to PCRE_CPPFLAGS
+ PCRE_CPPFLAGS="-I$PCREDIR/include"
PCRE_LDFLAGS="-L$PCREDIR/lib"
else
- AC_MSG_ERROR([the --with-pcredir directory "$PCREDIR" cannot be found])
+ AC_MSG_ERROR([the --with-pcredir directory "$PCREDIR" cannot be found])
fi
fi
fi
dnl Check that we can find the pcre.h header file
CPPFLAGS="$PCRE_CPPFLAGS"
- AC_CHECK_HEADER([pcre.h], [HAVE_PCRE=yes], [ADDRESS_STANDARDIZER=""])
+ AC_CHECK_HEADER([pcre.h], [HAVE_PCRE=yes], [ADDRESS_STANDARDIZER=""])
AC_SUBST([PCRE])
AC_SUBST([HAVE_PCRE])
AC_SUBST([ADDRESS_STANDARDIZER])
dnl Return the PCRE version number
AC_DEFINE_UNQUOTED([PCRE_VERSION], [$PCRE_VERSION], [PCRE library version])
AC_SUBST([PCRE_VERSION])
AC_SUBST([PCRE_CPPFLAGS])
AC_SUBST([PCRE_LDFLAGS])
else
@@ -1087,7 +1087,7 @@
RASTER="raster"
AC_MSG_RESULT([RASTER: Raster support requested])
- AC_CONFIG_HEADERS([raster/raster_config.h])
+ AC_CONFIG_HEADERS([raster/raster_config.h])
dnl
dnl Raster Version Information imported from raster/Version.config
@@ -1185,7 +1185,7 @@
AC_MSG_ERROR([PostGIS raster requires GDAL >= $GDAL_MIN_VERSION. Use --without-raster to build without raster support.])
fi
- AC_DEFINE_UNQUOTED([POSTGIS_GDAL_VERSION], [$POSTGIS_GDAL_VERSION], [GDAL library version])
+ AC_DEFINE_UNQUOTED([POSTGIS_GDAL_VERSION], [$POSTGIS_GDAL_VERSION], [GDAL library version])
AC_SUBST([POSTGIS_GDAL_VERSION])
dnl Check that OGR is enabled
@@ -1197,7 +1197,7 @@
fi
AC_MSG_RESULT([$OGR_ENABLED])
- dnl Extract the linker and include flags
+ dnl Extract the linker and include flags
LIBGDAL_LDFLAGS=`$GDAL_CONFIG --libs`
dnl LIBGDAL_DEPLIBS_LDFLAGS=`$GDAL_CONFIG --dep-libs`
LIBGDAL_CFLAGS=`$GDAL_CONFIG --cflags`
@@ -1302,37 +1302,37 @@
dnl Output the relevant files
-AC_OUTPUT([GNUmakefile
+AC_OUTPUT([GNUmakefile
extensions/Makefile
- extensions/postgis/Makefile
- extensions/postgis/postgis.control
- extensions/postgis_sfcgal/Makefile
- extensions/postgis_sfcgal/postgis_sfcgal.control
- extensions/postgis_topology/Makefile
- extensions/postgis_topology/postgis_topology.control
- extensions/postgis_tiger_geocoder/Makefile
- extensions/postgis_tiger_geocoder/postgis_tiger_geocoder.control
- extensions/address_standardizer/Makefile
+ extensions/postgis/Makefile
+ extensions/postgis/postgis.control
+ extensions/postgis_sfcgal/Makefile
+ extensions/postgis_sfcgal/postgis_sfcgal.control
+ extensions/postgis_topology/Makefile
+ extensions/postgis_topology/postgis_topology.control
+ extensions/postgis_tiger_geocoder/Makefile
+ extensions/postgis_tiger_geocoder/postgis_tiger_geocoder.control
+ extensions/address_standardizer/Makefile
extensions/address_standardizer/address_standardizer.control
- extensions/address_standardizer/address_standardizer_data_us.control
- liblwgeom/Makefile
- liblwgeom/cunit/Makefile
- liblwgeom/liblwgeom.h
- libpgcommon/Makefile
- libpgcommon/cunit/Makefile
- postgis/Makefile
- postgis/sqldefines.h
- loader/Makefile
- loader/cunit/Makefile
- topology/Makefile
- topology/test/Makefile
- regress/Makefile
- doc/Makefile
- doc/Makefile.comments
- doc/html/image_src/Makefile
- utils/Makefile
+ extensions/address_standardizer/address_standardizer_data_us.control
+ liblwgeom/Makefile
+ liblwgeom/cunit/Makefile
+ liblwgeom/liblwgeom.h
+ libpgcommon/Makefile
+ libpgcommon/cunit/Makefile
+ postgis/Makefile
+ postgis/sqldefines.h
+ loader/Makefile
+ loader/cunit/Makefile
+ topology/Makefile
+ topology/test/Makefile
+ regress/Makefile
+ doc/Makefile
+ doc/Makefile.comments
+ doc/html/image_src/Makefile
+ utils/Makefile
$RT_MAKEFILE_LIST])
dnl Display the configuration status information
