[postgis-tickets] [PostGIS] #3506: build variable not defined ?
trac at osgeo.org
Sun Aug 28 10:44:10 PDT 2016
Reporter: darkblueb | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.3
Component: postgis | Version: 2.2.x
Resolution: | Keywords: autotools, make
Comment (by robe):
darkblue_b are you all set with this. I thought you said you figured out
the issue. If so put it here for posterity and close out.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3506#comment:8>
