[postgis-tickets] [PostGIS] #3616: Pull changes to address standardizer from pagc repository
trac at osgeo.org
Tue Aug 30 10:53:20 PDT 2016
Reporter: woodbri | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.0
Component: postgis | Version: 2.2.x
Keywords: |
I'm not sure how changes to pagc address standardizer are synced, but I
just checked in a bug fix in:
http://svn.code.sf.net/p/pagc/code/branches/sew-refactor/postgresql/
* test_main.c - Added code to pass commandline options
* tokenize.c - Change to allow a MIXED token to follow an AMPERS token
There was a problem standardizing Canada data the contains a lot of roads
like:
123 rang 15e & 16e
The old code failed to standardize the "16e" as a MIXED token because a
MIXED token is only allowed to follow a predefined list of tokens that did
not include AMPERS. My change adds AMPERS to that list.
I don't think I have commit ability for postgis, but these changes should
get pulled into postgis.
Index: tokenize.c
--- tokenize.c (revision 362)
+++ tokenize.c (working copy)
@@ -27,7 +27,7 @@
#include <stddef.h>
#include "pagc_api.h"
-static SYMB precedes_identifier_list[] = { BOXT , ROAD , UNITH , PRETYP ,
BUILDH , RR , FAIL } ;
+static SYMB precedes_identifier_list[] = { BOXT , ROAD , AMPERS, UNITH ,
PRETYP , BUILDH , RR , FAIL } ;
static SYMB precedes_route_list[] = { TYPE , QUALIF , PROV , FAIL } ;
#ifdef COMBINE_FRACTS_WITH_NUMBS
static SYMB FractL[] = { FRACT , FAIL } ;
Index: test_main.c
--- test_main.c (revision 362)
+++ test_main.c (working copy)
@@ -103,6 +103,7 @@
if (p == q) break;
p = q;
nr++;
+ assert(nr < RULESIZE);
r++;
@@ -111,7 +112,7 @@
void Usage()
- printf("Usage: test_main [-o n] \n");
+ printf("Usage: test_main [-o n] lex.txt gaz.txt rules.txt \n");
printf(" -o n = options bit flag\n");
printf(" 1 = print lexicon\n");
printf(" 2 = print gazeteer\n");
@@ -139,15 +140,18 @@
int err;
int cnt;
int option = 0;
+ char *flex;
+ char *fgaz;
+ char *frules;
FILE *in;
- if (argc == 3 && !strcmp(argv[1], "-o")) {
+ if (argc > 3 && !strcmp(argv[1], "-o")) {
option = strtol(argv[2], NULL, 10);
argc -= 2;
argv += 2;
- else if (argc != 1)
+ else if (argc != 4)
Usage();
std = std_init();
@@ -156,7 +160,8 @@
lex = lex_init(std->err_p);
assert(lex);
- in = fopen(LEXIN, "rb");
+ flex = argv[1];
+ in = fopen(flex, "rb");
assert(in);
cnt = 0;
@@ -184,7 +189,8 @@
gaz = lex_init(std->err_p);
assert(gaz);
- in = fopen(GAZIN, "rb");
+ fgaz = argv[2];
+ in = fopen(fgaz, "rb");
assert(in);
cnt = 0;
@@ -215,7 +221,8 @@
/* ************ RULES **************** */
- in = fopen(RULESIN, "rb");
+ frules = argv[3];
+ in = fopen(frules, "rb");
assert(in);
cnt = 0;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3616>
