[postgis-tickets] [PostGIS] #3445: topology: postgres runs out of memory on loading geometry using toTopoGeom
trac at osgeo.org
Mon Feb 1 07:31:10 PST 2016
Reporter: rulus | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.2
Component: topology | Version: 2.2.x
Resolution: | Keywords:
Comment (by strk):
Disabling the OOM killer should make debugging easier.
Splitting the inputs to avoid a single new geometry's bounding box to
intersect lots of existing components should reduce memory usage.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3445#comment:2>
