[postgis-tickets] [PostGIS] #3445: topology: postgres runs out of memory on loading geometry using toTopoGeom
trac at osgeo.org
Tue Feb 2 02:43:08 PST 2016
Reporter: rulus | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.2
Component: topology | Version: 2.2.x
Resolution: | Keywords:
Comment (by rulus):
Adding a small nuance here: this might actually not be a bug :)
By disabling the OOM killer and raising the memory of the VM (from 2GB to
4GB) I managed to import the failing geometry without problems. It seems
that it's just using more memory than I thought it would..
Thanks for the suggestions!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3445#comment:3>
