[postgis-tickets] [PostGIS] #3429: upgrade from 2.1.3 to 2.3.0dev enters infinite loop
trac at osgeo.org
Tue Feb 2 02:54:38 PST 2016
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.2.2
Component: build/upgrade/install | Version: 2.2.x
Resolution: | Keywords:
Comment (by Talkless):
We had same problem on Debian Wheezy with PostgreSQL 9.4 and Postgis 2.1
from pgdg repository.
Package updates where installed on which new postgresql-9.4-postgis-2.2
package was installed automatically.
Our DBA tried to update Postgis extension, but some strange errors
occurred, like something about changing "postgis.backed" and this infinite
loop mentioned in bug report.
perf top showed that postgres process is executing init_rt_allocator,
rt_something_allocator functions from both postgis-2.1.so and
postgis-2.2.so. Had to sigkill (sigterm, hup, int did not work). Only
after removing Postgis 2.1 extension update was successfull.
Problem is I do not how to reproduces it, because if I install
postgresql-9.4-postigs-2.1, 2.2 packages is also automatically installed,
so I get Postgis 2.2 extension by default, if I understand correctly.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3429#comment:15>
