[postgis-tickets] [PostGIS] #3429: upgrade from 2.1.3 to 2.3.0dev enters infinite loop
trac at osgeo.org
Tue Feb 2 03:01:49 PST 2016
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.2.2
Component: build/upgrade/install | Version: 2.2.x
Resolution: | Keywords:
Comment (by strk):
My suspect is with different implementations of the _same_ signature being
loaded in memory at the same time (due to both old and new postgis module
loaded within the same process) and runtime linker picking one for the
other, triggering Really Bad Things like this.
The last time we fixed this by specifying --exlcude-libs (#3281) but I'm
not sure it applies here, especially as old packages might still be
exposing the methods outside.
I guess one fix could be disabling the major-upgrade check (responsible of
loading the old library), at least during EXTENSION upgrade (which should
not allow upgrading between major releases, anyway).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3429#comment:16>
