[postgis-tickets] [PostGIS] #3430: dump/restore of tiger geocoder extension fails
trac at osgeo.org
Wed Feb 3 07:38:25 PST 2016
Reporter: strk | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.9
Component: tiger geocoder | Version: 2.1.x
Resolution: | Keywords:
Comment (by strk):
also works with default_version=2.2.2dev.
It takes default_version=2.1.9dev to reproduce, from "2.1.3" to
"2.1.9dev".
SET
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
pg_restore: [archiver (db)] Error while PROCESSING TOC:
pg_restore: [archiver (db)] Error from TOC entry 3344; 0 51783822 TABLE
DATA geocode_settings strk
pg_restore: [archiver (db)] COPY failed for table "geocode_settings":
ERROR: duplicate key value violates unique constraint
"geocode_settings_pkey"
DETAIL: Key (name)=(debug_geocode_address) already exists.
CONTEXT: COPY geocode_settings, line 1
WARNING: errors ignored on restore: 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3430#comment:10>
