[postgis-tickets] [PostGIS] #3450: 2.2 -> 2.3.0dev leaves 15 function behind
PostGIS trac at osgeo.org
Mon Feb 8 08:16:19 PST 2016
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 2.3.0
 Component:  build/upgrade/install  |    Version:  2.2.x
Resolution:                         |   Keywords:
Comment (by robe):
 Just tried upgrading from 2.2.1 (released version), to 2.3.0dev.  First
 time around I got the gdal_path redefined notice (this was using the GUI
 in pgAdmin).
 Then trying again with :
 ALTER EXTENSION postgis
   UPDATE TO "2.3.0dev";
 It succeeded but gave these notices:
 WARNING:  'postgis.backend' is already set and cannot be changed until you
 reconnect
 CONTEXT:  SQL statement "SELECT                  postgis_lib_version()"
 PL/pgSQL function postgis_major_version_check() line 21 at SQL statement
 Query returned successfully with no result in 350 msec.
 Then when I dropped the extension and attempted to recreate with
 create extension postgis version "2.2.1";
 I got failure -
 ERROR:  attempt to redefine parameter "postgis.gdal_datapath"
 This is
 PostgreSQL 9.4.4, compiled by Visual C++ build 1800, 64-bit
 So it does seem we've still got problems.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3450#comment:5>
