[postgis-tickets] [PostGIS] #3450: 2.2 -> 2.3.0dev leaves 15 function behind
trac at osgeo.org
Mon Feb 8 08:57:44 PST 2016
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.0
Component: build/upgrade/install | Version: 2.2.x
Resolution: | Keywords:
Comment (by strk):
Robe please use another ticket for the gdal_datapath issue. This one is to
not leave dropped function behind. Left over after r14629 (still to be
backported to 2.2 branch) are:
geometry_spgist_leaf_consistent_2d | internal, geometry, integer
geometry_spgist_inner_consistent_2d | internal, geometry, integer
geometry_spgist_picksplit_2d | internal, internal
geometry_spgist_config_2d | internal, internal
geometry_spgist_choose_2d | internal, internal
st_seteffectivearea | geometry, double precision DEFAULT
0
pgis_twkb_accum_transfn | internal, geometry, integer
pgis_twkb_accum_transfn | internal, geometry, integer, bigint
bigint, boolean
bigint, boolean, boolean
pgis_twkb_accum_finalfn | internal
geometry_distance_centroid | geom1 gidx, geom2 gidx
geometry_distance_box | gidx1 gidx, gidx2 gidx
geometry_distance_box_nd | geom1 geometry, geom2 geometry
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3450#comment:7>
