[postgis-tickets] [PostGIS] #3450: 2.2 -> 2.3.0dev leaves 15 function behind
PostGIS trac at osgeo.org
Mon Feb 8 09:17:54 PST 2016
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 2.3.0
 Component:  build/upgrade/install  |    Version:  2.2.x
Resolution:                         |   Keywords:
Comment (by strk):
 Code was broken, r14630 reverts it. All functions are left-over at the
 moment.
 I guess a general solution would be to intercept and wrap every line
 starting with DROP to make it extension-aware, and I even see it done for
 the "rtpostgis_upgrade.sql" rule.
 But I won't be looking at this any soon, so if you want to continue here
 Regina, you're welcome!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3450#comment:9>
