[postgis-tickets] [PostGIS] #3450: 2.2 -> 2.3.0dev leaves 15 function behind
trac at osgeo.org
Tue Feb 9 00:25:06 PST 2016
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.0
Component: build/upgrade/install | Version: 2.2.x
Resolution: | Keywords:
Comment (by strk):
I'm actually looking at this now.
Regina, is the comment about "CREATE|DROP CAST" in
extension/postgis/Makefile.in still valid ? It says
postgis_extension_drop_if_exists cannot drop CASTs but then there's code
to produce rtpostgis_upgrade.sql in the _same_ Makefile.in that does use
it ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3450#comment:10>
