[postgis-tickets] r14630 - Revert "Unregister all functions before starting postgis extention upgrade"
Sandro Santilli strk at keybit.net
Mon Feb 8 09:16:13 PST 2016
Author: strk
Date: 2016-02-08 09:16:12 -0800 (Mon, 08 Feb 2016)
New Revision: 14630
Added:
   trunk/extensions/postgis/sql_bits/remove_from_extension.sql.in
   trunk/extensions/postgis/Makefile.in
   trunk/postgis/postgis_drop_after.sql
This reverts r14629 (see #3450)
The code was broken (but the idea is still good to evaluate)
Modified: trunk/extensions/postgis/Makefile.in
--- trunk/extensions/postgis/Makefile.in	2016-02-08 16:54:36 UTC (rev 14629)
+++ trunk/extensions/postgis/Makefile.in	2016-02-08 17:16:12 UTC (rev 14630)
@@ -100,14 +100,10 @@
 sql_bits/raster_comments.sql: ../../doc/raster_comments.sql
 	cp $< $@
-sql_bits/postgis_extension_upgrade_minor.sql: ../postgis_extension_helper.sql sql_bits/postgis_upgrade.sql sql_bits/rtpostgis_upgrade.sql ../../doc/raster_comments.sql ../../doc/postgis_comments.sql ../postgis_extension_helper_uninstall.sql
 #postgis_extension_upgrade_minor.sql is the one that contains both postgis AND raster
+#TODO: what about postgis_drop_after.sql ? where does it fit ??
 	echo '\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \quit' > $@
-	# NOTE: good functions are always re-added by the upgrade scripts,
-	#       so unregistering them all here ensures the removed ones
-	#       can be removed on upgrade.
-	echo "SELECT postgis_extension_remove_objects('postgis', 'FUNCTION');" >> $@
 	cat $^ >> $@
 sql_minor_upgrade: sql_bits/postgis_extension_upgrade_minor.sql
Added: trunk/extensions/postgis/sql_bits/remove_from_extension.sql.in
--- trunk/extensions/postgis/sql_bits/remove_from_extension.sql.in	                        (rev 0)
+++ trunk/extensions/postgis/sql_bits/remove_from_extension.sql.in	2016-02-08 17:16:12 UTC (rev 14630)
@@ -0,0 +1,29 @@
+-- PostGIS - Spatial Types for PostgreSQL
+-- http://postgis.net
+-- Copyright (C) 2011 Regina Obe <lr at pcorp.us>
+-- This is free software; you can redistribute and/or modify it under
+-- the terms of the GNU General Public Licence. See the COPYING file.
+-- Author: Regina Obe <lr at pcorp.us>
+-- This drops extension helper functions
+-- and should be called at the end of the extension upgrade file
+-- removes all postgis_topology functions from postgis_topology extension since they will be readded
+-- during upgrade
+SELECT postgis_extension_remove_objects('postgis', 'FUNCTION');
+SELECT postgis_extension_remove_objects('postgis', 'AGGREGATE');
+SELECT postgis_extension_drop_if_exists('postgis', 'DROP VIEW raster_columns');
+SELECT postgis_extension_drop_if_exists('postgis', 'DROP TYPE wktgeomval');
+SELECT postgis_extension_drop_if_exists('postgis', 'DROP TYPE _wktgeomval');
+SELECT postgis_extension_drop_if_exists('postgis', 'DROP TYPE raster_columns');
+SELECT postgis_extension_drop_if_exists('postgis', 'DROP TYPE _raster_columns');
+-- these got changed to out paramters in 2.1
+SELECT postgis_extension_drop_if_exists('postgis', 'DROP TYPE summarystats');
+SELECT postgis_extension_drop_if_exists('postgis', 'DROP TYPE quantile');
+SELECT postgis_extension_drop_if_exists('postgis', 'DROP TYPE valuecount');
+SELECT postgis_extension_drop_if_exists('postgis', 'DROP TYPE histogram');
Modified: trunk/postgis/postgis_drop_after.sql
--- trunk/postgis/postgis_drop_after.sql	2016-02-08 16:54:36 UTC (rev 14629)
+++ trunk/postgis/postgis_drop_after.sql	2016-02-08 17:16:12 UTC (rev 14630)
@@ -147,4 +147,3 @@
 DROP FUNCTION IF EXISTS ST_AsBinary(text); -- deprecated in 2.0
 DROP FUNCTION IF EXISTS postgis_uses_stats(); -- deprecated in 2.0
-DROP FUNCTION IF EXISTS st_astwkb(geometry,integer,bigint,bool,bool); -- temporarely introduced before 2.2.0 final
