[postgis-tickets] [PostGIS] #3451: Schema-qualify table names to avoid search path confusion or "column does not exist" error
PostGIS trac at osgeo.org
Mon Feb 8 11:03:07 PST 2016
not exist" error
 Reporter:  mst                                  |      Owner:  robe
     Type:  defect                               |     Status:  new
 Priority:  medium                               |  Milestone:  PostGIS
                                                 |  2.2.2
Component:  tiger geocoder                       |    Version:  2.2.x
 Keywords:  table name, column does not exist,   |
  schema                                         |
 At least some functions do not appear to schema-qualify table names and
 end up referencing the wrong table.  This results in an error stating a
 column does not exist:
 ERROR:  column co.statefp does not exist
 LINE 2: ...cefp = p.placefp)  LEFT JOIN county co ON ('25' = co.statefp...
 CONTEXT:  PL/pgSQL function geocode_address(norm_addy,integer,geometry)
 line 383 at FOR over EXECUTE statement
 PL/pgSQL function geocode(norm_addy,integer,geometry) line 14 at FOR over
 SELECT rows
 PL/pgSQL function geocode(character varying,integer,geometry) line 26 at
 RETURN QUERY
 In this case, the county table existed in another schema in the search
 path.  Other table names used in the tiger and tiger_data schemas may also
 be in use (such as state, place, addr, zip_lookup, zip_state, etc. as well
 as their state-prefixed counterparts ma_place, id_addr, etc.).  Schema-
 qualifying all table names should avoid this issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3451>
