[postgis-tickets] [PostGIS] #3454: Topology search_path lost on dump/restore
PostGIS trac at osgeo.org
Tue Feb 9 09:29:41 PST 2016
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS Future
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:  topology, restore
Comment (by strk):
 Hint from irc://irc.freenode.org/#postgresql
 < Zr40> if you set that per-database or per-user, pg_dumpall --globals-
 only would include it
 < strk> Zr40: so, any way to include it in a single-database dump ?
 < Zr40> strk: no, pg_dump doesn't include it
 < Zr40> strk: I'd add it as a separate preparation step for your tests
 after restoring
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3454#comment:1>
