[postgis-tickets] [PostGIS] #3454: Topology search_path lost on dump/restore
PostGIS trac at osgeo.org
Tue Feb 9 10:22:25 PST 2016
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS Future
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  wontfix                |   Keywords:  topology, restore
Changes (by strk):
 * status:  new => closed
 * resolution:   => wontfix
Comment:
 Closing as it's not a bug (but something to keep in mind).
 With r14655 (trunk) and r14656 (2.2 branch) I've made run_test.pl re-add
 the topology schema, using the `topology.AddToSearchPath` function which
 is part of the topology support.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3454#comment:4>
