[postgis-tickets] [PostGIS] #3423: CREATE EXTENSION postgis fails with "ERROR: could not load library "/usr/pgsql-9.5/lib/postgis-2.2.so": /usr/pgsql-9.5/lib/postgis-2.2.so: undefined symbol: GEOSClipByRect"
PostGIS trac at osgeo.org
Wed Feb 10 16:52:37 PST 2016
  Reporter:  motiumansky  |      Owner:  pramsey
      Type:  defect       |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 2.2.2
 Component:  postgis      |    Version:  2.2.x
Resolution:               |   Keywords:
Comment (by dcalde):
 I had the same error, but was able to fix it. If I had installed on a new
 server, this would probably not have been a problem, but this server is
 already running pg 9.4 with postgis 2.1.
 I was merely running an old version of GEOS. A simple 'yum update geos'
 did the trick.
 [root at ip-10-0-4-58 data]# yum info geos
 Loaded plugins: fastestmirror
 Loading mirror speeds from cached hostfile
  * base: centos.mirror.serversaustralia.com.au
  * epel: epel.mirror.digitalpacific.com.au
  * extras: mirror.ventraip.net.au
  * updates: centos.mirror.serversaustralia.com.au
 Installed Packages
 Arch        : x86_64
 Version     : 3.4.2
 Release     : 1.rhel7
 Repo        : installed
 From repo   : pgdg94
 Summary     : GEOS is a C++ port of the Java Topology Suite
 URL         : http://trac.osgeo.org/geos/
 License     : LGPLv2
 Description : GEOS (Geometry Engine - Open Source) is a C++ port of the
 Java Topology
             : Suite (JTS). As such, it aims to contain the complete
 functionality of
             : JTS in C++. This includes all the OpenGIS "Simple Features
 for SQL" spatial
             : predicate functions and spatial operators, as well as
 specific JTS topology
             : functions such as IsValid()
 Available Packages
 Arch        : x86_64
 Version     : 3.5.0
 Release     : 1.rhel7
 Repo        : pgdg95/7/x86_64
 License     : LGPLv2
 Java Topology
 functionality of
 for SQL" spatial
 [root at ip-10-0-4-58 data]# yum update geos
 Resolving Dependencies
 --> Running transaction check
 ---> Package geos.x86_64 0:3.4.2-1.rhel7 will be updated
 ---> Package geos.x86_64 0:3.5.0-1.rhel7 will be an update
 --> Finished Dependency Resolution
 Dependencies Resolved
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3423#comment:16>
