[postgis-tickets] [PostGIS] #3423: CREATE EXTENSION postgis fails with "ERROR: could not load library "/usr/pgsql-9.5/lib/postgis-2.2.so": /usr/pgsql-9.5/lib/postgis-2.2.so: undefined symbol: GEOSClipByRect"
PostGIS trac at osgeo.org
Fri Feb 26 07:49:58 PST 2016
  Reporter:  motiumansky  |      Owner:  pramsey
      Type:  defect       |     Status:  closed
  Priority:  medium       |  Milestone:  PostGIS 2.2.2
 Component:  postgis      |    Version:  2.2.x
Resolution:  worksforme   |   Keywords:
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => worksforme
Comment:
 I'm closing this because it's out of our hands as either a packaging issue
 or just a local configuration issue (use `find` to try and track down
 copies of libgeos that might be installed in places you don't expect)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3423#comment:17>
