[postgis-tickets] r14676 - Add doc entry for ST_ClusterDBSCAN
Daniel Baston
dbaston at gmail.com
Wed Feb 24 04:48:55 PST 2016
Author: dbaston
Date: 2016-02-24 04:48:55 -0800 (Wed, 24 Feb 2016)
New Revision: 14676
trunk/doc/reference_measure.xml
Modified: trunk/doc/reference_measure.xml
--- trunk/doc/reference_measure.xml 2016-02-24 11:40:55 UTC (rev 14675)
+++ trunk/doc/reference_measure.xml 2016-02-24 12:48:55 UTC (rev 14676)
@@ -4160,12 +4160,78 @@
<para><xref linkend="ST_Contains"/>, <xref linkend="ST_Equals"/>, <xref linkend="ST_IsValid"/></para>
</refsection>
</refentry>
+ <refentry id="ST_ClusterDBSCAN">
+ <refnamediv>
+ <refname>ST_ClusterDBSCAN</refname>
+ <refpurpose>Windowing function that returns integer id for the cluster each input geometry is in.</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>integer <function>ST_ClusterDBSCAN</function></funcdef>
+ <paramdef><type>geometry </type>
+ <parameter>geom</parameter></paramdef>
+ <paramdef><type>float8 </type>
+ <parameter>eps</parameter></paramdef>
+ <paramdef><type>int </type>
+ <parameter>minpoints</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>Returns cluster number for each input geometry, based on a 2D
+ implementation of the
+ <ulink url="https://en.wikipedia.org/wiki/DBSCAN">DBSCAN</ulink>
+ algorithm. An input geometry will be added to a cluster if it is
+ within <varname>eps</varname> distance of at least
+ <varname>minpoints</varname> other input geometries.
+ </para>
+ </refsection>
+ <refsection>
+ <title>Examples</title>
+ <para>
+ Assigning a cluster number to each parcel point:
+ </para>
+ <programlisting>
+SELECT parcel_id, ST_ClusterDBSCAN(geom, eps := 0.5, minpoints := 5) over () AS cid
+FROM parcels;
+</programlisting>
+ <para>
+ Combining parcels with the same cluster number into a single geometry:
+ </para>
+ <programlisting>
+SELECT cid, ST_Collect(geom) AS cluster_geom, array_agg(parcel_id) AS ids_in_cluster FROM (
+ SELECT parcel_id, ST_ClusterDBSCAN(geom, eps := 0.5, minpoints := 5) over () AS cid, geom
+ FROM parcels) sq
+GROUP BY cid;
+</programlisting>
+ </refsection>
+ <refsection>
+ <title>See Also</title>
+ <para><xref linkend="ST_ClusterKMeans"/></para>
+ </refsection>
+ </refentry>
<refentry id="ST_ClusterKMeans">
<refnamediv>
<refname>ST_ClusterKMeans</refname>
- <refpurpose>Windowing function that returns integer for cluster each input geometry is in.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -4202,8 +4268,7 @@
<refsection>
- <!-- <para><xref linkend="ST_ClusterDBSCAN"/></para> -->
- <para>See also ST_ClusterDBSCAN</para>
+ <para><xref linkend="ST_ClusterDBSCAN"/></para>
</refsection>
</refentry>
