[postgis-tickets] r14677 - Move all ST_Cluster* docs to measurement section
Daniel Baston
dbaston at gmail.com
Wed Feb 24 05:00:16 PST 2016
Author: dbaston
Date: 2016-02-24 05:00:16 -0800 (Wed, 24 Feb 2016)
New Revision: 14677
trunk/doc/reference_measure.xml
trunk/doc/reference_processing.xml
Modified: trunk/doc/reference_measure.xml
--- trunk/doc/reference_measure.xml 2016-02-24 12:48:55 UTC (rev 14676)
+++ trunk/doc/reference_measure.xml 2016-02-24 13:00:16 UTC (rev 14677)
@@ -1032,6 +1032,236 @@
</refsection>
</refentry>
+ <refentry id="ST_ClusterDBSCAN">
+ <refnamediv>
+ <refname>ST_ClusterDBSCAN</refname>
+ <refpurpose>Windowing function that returns integer id for the cluster each input geometry is in.</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>integer <function>ST_ClusterDBSCAN</function></funcdef>
+ <paramdef><type>geometry </type>
+ <parameter>geom</parameter></paramdef>
+ <paramdef><type>float8 </type>
+ <parameter>eps</parameter></paramdef>
+ <paramdef><type>int </type>
+ <parameter>minpoints</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>Returns cluster number for each input geometry, based on a 2D
+ implementation of the
+ <ulink url="https://en.wikipedia.org/wiki/DBSCAN">DBSCAN</ulink>
+ algorithm. An input geometry will be added to a cluster if it is
+ within <varname>eps</varname> distance of at least
+ <varname>minpoints</varname> other input geometries.
+ </para>
+ </refsection>
+ <refsection>
+ <title>Examples</title>
+ <para>
+ Assigning a cluster number to each parcel point:
+ </para>
+ <programlisting>
+SELECT parcel_id, ST_ClusterDBSCAN(geom, eps := 0.5, minpoints := 5) over () AS cid
+FROM parcels;
+</programlisting>
+ <para>
+ Combining parcels with the same cluster number into a single geometry:
+ </para>
+ <programlisting>
+SELECT cid, ST_Collect(geom) AS cluster_geom, array_agg(parcel_id) AS ids_in_cluster FROM (
+ SELECT parcel_id, ST_ClusterDBSCAN(geom, eps := 0.5, minpoints := 5) over () AS cid, geom
+ FROM parcels) sq
+GROUP BY cid;
+ </programlisting>
+ </refsection>
+ <refsection>
+ <title>See Also</title>
+ <para>
+ <xref linkend="ST_ClusterKMeans"/>,
+ <xref linkend="ST_ClusterIntersecting"/>,
+ <xref linkend="ST_ClusterWithin"/>
+ </para>
+ </refsection>
+ </refentry>
+ <refentry id="ST_ClusterIntersecting">
+ <refnamediv>
+ <refname>ST_ClusterIntersecting</refname>
+ <refpurpose>Aggregate. Returns an array with the connected components of a set of geometries</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>geometry[] <function>ST_ClusterIntersecting</function></funcdef>
+ <paramdef><type>geometry </type> <parameter>g</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <para>ST_ClusterIntersecting is an aggregate function that returns an array of GeometryCollections, where each GeometryCollection represents an interconnected set of geometries.</para>
+ <para>Availability: 2.2.0 - requires GEOS </para>
+ </refsection>
+ <refsection>
+ <programlisting>
+WITH testdata AS
+ (SELECT unnest(ARRAY['LINESTRING (0 0, 1 1)'::geometry,
+ 'LINESTRING (5 5, 4 4)'::geometry,
+ 'LINESTRING (6 6, 7 7)'::geometry,
+ 'LINESTRING (0 0, -1 -1)'::geometry,
+ 'POLYGON ((0 0, 4 0, 4 4, 0 4, 0 0))'::geometry]) AS geom)
+SELECT ST_AsText(unnest(ST_ClusterIntersecting(geom))) FROM testdata;
+--result
+st_astext
+GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4 4),LINESTRING(0 0,-1 -1),POLYGON((0 0,4 0,4 4,0 4,0 0)))
+GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
+ </programlisting>
+ </refsection>
+ <refsection>
+ <para>
+ <xref linkend="ST_ClusterDBSCAN" />,
+ <xref linkend="ST_ClusterKMeans" />,
+ <xref linkend="ST_ClusterWithin" />
+ </para>
+ </refsection>
+ </refentry>
+ <refentry id="ST_ClusterKMeans">
+ <refnamediv>
+ <refname>ST_ClusterKMeans</refname>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>integer <function>ST_ClusterKMeans</function></funcdef>
+ <paramdef><type>integer </type>
+ <parameter>number_of_clusters</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <para>Returns 2D distance based
+ <ulink url="https://en.wikipedia.org/wiki/K-means_clustering">k-means</ulink>
+ cluster number for each input geometry. The distance used for clustering is the
+ distance between the centroids of the geometries.
+ </para>
+ </refsection>
+ <refsection>
+ <programlisting>
+SELECT ST_ClusterKMeans(geom, 5) over (), geom, parcel_id
+FROM parcels;
+</programlisting>
+ </refsection>
+ <refsection>
+ <para>
+ <xref linkend="ST_ClusterDBSCAN"/>,
+ <xref linkend="ST_ClusterIntersecting" />,
+ </para>
+ </refsection>
+ </refentry>
+ <refentry id="ST_ClusterWithin">
+ <refnamediv>
+ <refname>ST_ClusterWithin</refname>
+ <refpurpose>Aggregate. Returns an array of GeometryCollections, where each GeometryCollection represents a set of geometries separated by no more than the specified distance.</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>geometry[] <function>ST_ClusterWithin</function></funcdef>
+ <paramdef><type>float8 </type> <parameter>distance</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <para>ST_ClusterWithin is an aggregate function that returns an array of GeometryCollections, where each GeometryCollection represents a set of geometries separated by no more than the specified distance.</para>
+ <para>Availability: 2.2.0 - requires GEOS</para>
+ </refsection>
+ <refsection>
+ <programlisting>
+WITH testdata AS
+SELECT ST_AsText(unnest(ST_ClusterWithin(geom, 1.4))) FROM testdata;
+--result
+st_astext
+ </programlisting>
+ </refsection>
+ <refsection>
+ <para>
+ </para>
+ </refsection>
+ </refentry>
<refentry id="ST_Contains">
<refnamediv>
<refname>ST_Contains</refname>
@@ -4160,117 +4390,6 @@
<para><xref linkend="ST_Contains"/>, <xref linkend="ST_Equals"/>, <xref linkend="ST_IsValid"/></para>
</refsection>
</refentry>
- <refentry id="ST_ClusterDBSCAN">
- <refnamediv>
- <refname>ST_ClusterDBSCAN</refname>
- <refpurpose>Windowing function that returns integer id for the cluster each input geometry is in.</refpurpose>
- </refnamediv>
- <refsynopsisdiv>
- <funcsynopsis>
- <funcprototype>
- <funcdef>integer <function>ST_ClusterDBSCAN</function></funcdef>
- <paramdef><type>geometry </type>
- <parameter>geom</parameter></paramdef>
- <paramdef><type>float8 </type>
- <parameter>eps</parameter></paramdef>
- <paramdef><type>int </type>
- <parameter>minpoints</parameter></paramdef>
- </funcprototype>
- </funcsynopsis>
- </refsynopsisdiv>
- <refsection>
- <title>Description</title>
- <para>Returns cluster number for each input geometry, based on a 2D
- implementation of the
- <ulink url="https://en.wikipedia.org/wiki/DBSCAN">DBSCAN</ulink>
- algorithm. An input geometry will be added to a cluster if it is
- within <varname>eps</varname> distance of at least
- <varname>minpoints</varname> other input geometries.
- </para>
- </refsection>
- <refsection>
- <title>Examples</title>
- <para>
- Assigning a cluster number to each parcel point:
- </para>
- <programlisting>
-SELECT parcel_id, ST_ClusterDBSCAN(geom, eps := 0.5, minpoints := 5) over () AS cid
-FROM parcels;
-</programlisting>
- <para>
- Combining parcels with the same cluster number into a single geometry:
- </para>
- <programlisting>
-SELECT cid, ST_Collect(geom) AS cluster_geom, array_agg(parcel_id) AS ids_in_cluster FROM (
- SELECT parcel_id, ST_ClusterDBSCAN(geom, eps := 0.5, minpoints := 5) over () AS cid, geom
- FROM parcels) sq
-GROUP BY cid;
-</programlisting>
- </refsection>
- <refsection>
- <title>See Also</title>
- <para><xref linkend="ST_ClusterKMeans"/></para>
- </refsection>
- </refentry>
- <refentry id="ST_ClusterKMeans">
- <refnamediv>
- <refname>ST_ClusterKMeans</refname>
- </refnamediv>
- <refsynopsisdiv>
- <funcsynopsis>
- <funcprototype>
- <funcdef>integer <function>ST_ClusterKMeans</function></funcdef>
- <paramdef><type>integer </type>
- <parameter>number_of_clusters</parameter></paramdef>
- </funcprototype>
- </funcsynopsis>
- </refsynopsisdiv>
- <refsection>
- <para>Returns 2D distance based
- <ulink url="https://en.wikipedia.org/wiki/K-means_clustering">k-means</ulink>
- cluster number for each input geometry. The distance used for clustering is the
- distance between the centroids of the geometries.
- </para>
- </refsection>
- <refsection>
- <programlisting>
-SELECT ST_ClusterKMeans(geom, 5) over (), geom, parcel_id
-FROM parcels;
-</programlisting>
- </refsection>
- <refsection>
- <para><xref linkend="ST_ClusterDBSCAN"/></para>
- </refsection>
- </refentry>
</sect1>
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml 2016-02-24 12:48:55 UTC (rev 14676)
+++ trunk/doc/reference_processing.xml 2016-02-24 13:00:16 UTC (rev 14677)
@@ -416,113 +416,6 @@
</refsection>
</refentry>
- <refentry id="ST_ClusterIntersecting">
- <refnamediv>
- <refname>ST_ClusterIntersecting</refname>
- <refpurpose>Aggregate. Returns an array with the connected components of a set of geometries</refpurpose>
- </refnamediv>
- <refsynopsisdiv>
- <funcsynopsis>
- <funcprototype>
- <funcdef>geometry[] <function>ST_ClusterIntersecting</function></funcdef>
- <paramdef><type>geometry </type> <parameter>g</parameter></paramdef>
- </funcprototype>
- </funcsynopsis>
- </refsynopsisdiv>
- <refsection>
- <para>ST_ClusterIntersecting is an aggregate function that returns an array of GeometryCollections, where each GeometryCollection represents an interconnected set of geometries.</para>
- <para>Availability: 2.2.0 - requires GEOS </para>
- </refsection>
- <refsection>
- <programlisting>
-WITH testdata AS
- (SELECT unnest(ARRAY['LINESTRING (0 0, 1 1)'::geometry,
- 'LINESTRING (5 5, 4 4)'::geometry,
- 'LINESTRING (6 6, 7 7)'::geometry,
- 'LINESTRING (0 0, -1 -1)'::geometry,
- 'POLYGON ((0 0, 4 0, 4 4, 0 4, 0 0))'::geometry]) AS geom)
-SELECT ST_AsText(unnest(ST_ClusterIntersecting(geom))) FROM testdata;
---result
-st_astext
-GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4 4),LINESTRING(0 0,-1 -1),POLYGON((0 0,4 0,4 4,0 4,0 0)))
-GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
- </programlisting>
- </refsection>
- <refsection>
- <para>
- <xref linkend="ST_ClusterWithin" />,
- </para>
- </refsection>
- </refentry>
- <refentry id="ST_ClusterWithin">
- <refnamediv>
- <refname>ST_ClusterWithin</refname>
- <refpurpose>Aggregate. Returns an array of GeometryCollections, where each GeometryCollection represents a set of geometries separated by no more than the specified distance.</refpurpose>
- </refnamediv>
- <refsynopsisdiv>
- <funcsynopsis>
- <funcprototype>
- <funcdef>geometry[] <function>ST_ClusterWithin</function></funcdef>
- <paramdef><type>float8 </type> <parameter>distance</parameter></paramdef>
- </funcprototype>
- </funcsynopsis>
- </refsynopsisdiv>
- <refsection>
- <para>ST_ClusterWithin is an aggregate function that returns an array of GeometryCollections, where each GeometryCollection represents a set of geometries separated by no more than the specified distance.</para>
- <para>Availability: 2.2.0 - requires GEOS</para>
- </refsection>
- <refsection>
- <programlisting>
-WITH testdata AS
-SELECT ST_AsText(unnest(ST_ClusterWithin(geom, 1.4))) FROM testdata;
---result
-st_astext
- </programlisting>
- </refsection>
- <refsection>
- <para>
- <xref linkend="ST_ClusterIntersecting" />,
- </para>
- </refsection>
- </refentry>
<refentry id="ST_Collect">
<refnamediv>
<refname>ST_Collect</refname>
