[postgis-tickets] r14688 - Preliminary script to add search path to functions fix restore issues
Regina Obe lr at pcorp.us
Wed Feb 24 09:13:36 PST 2016
Author: robe
Date: 2016-02-24 09:13:36 -0800 (Wed, 24 Feb 2016)
New Revision: 14688
Added:
   trunk/postgis/postgis_functions_search_path.sql
References #2485
Added: trunk/postgis/postgis_functions_search_path.sql
--- trunk/postgis/postgis_functions_search_path.sql	                        (rev 0)
+++ trunk/postgis/postgis_functions_search_path.sql	2016-02-24 17:13:36 UTC (rev 14688)
@@ -0,0 +1,43 @@
+-- PostGIS - Spatial Types for PostgreSQL
+-- http://postgis.net
+-- Copyright 2016 Regina Obe
+-- This is free software; you can redistribute and/or modify it under
+-- the terms of the GNU General Public Licence. See the COPYING file.
+-- This routine adds search_path to functions known to have issues
+-- during restore.  Functions that call other postgis functions
+-- or spatial_ref_sys should be in here
+-- These are functions that are called by restore process for purposes of
+-- creating indexes, creating constraints, and creating materialized views
+-- Also functions that are used in foreign tables
+-- that call other postgis functions.  Eventually all functions should be here
+-- At that point we decide to add to all functions,
+-- this script should be autogenerated
+DO language plpgsql
+DECLARE param_postgis_schema text;
+BEGIN
+-- check if PostGIS is already installed
+param_postgis_schema = (SELECT n.nspname from pg_extension e join pg_namespace n on e.extnamespace = n.oid WHERE extname = 'postgis');
+-- if in middle install, it will be the current_schema or what was there already
+param_postgis_schema = COALESCE(param_postgis_schema, current_schema());
+EXECUTE 'set search_path TO ' || quote_ident(param_postgis_schema);
+-- PostGIS geometry funcs
+EXECUTE 'ALTER FUNCTION st_transform(geometry, integer) SET search_path=' || quote_ident(param_postgis_schema) || ';';
+-- PostGIS raster funcs
+EXECUTE 'ALTER FUNCTION _raster_constraint_pixel_types(raster) SET search_path=' || quote_ident(param_postgis_schema) || ';';
+EXECUTE 'ALTER FUNCTION _raster_constraint_info_regular_blocking(name,name,name) SET search_path=' || quote_ident(param_postgis_schema) || ';';
+END;
\ No newline at end of file
