[postgis-tickets] r14687 - #3437, ST_Intersects incorrect for MultiPoints
Daniel Baston
dbaston at gmail.com
Wed Feb 24 08:46:51 PST 2016
Author: dbaston
Date: 2016-02-24 08:46:50 -0800 (Wed, 24 Feb 2016)
New Revision: 14687
branches/2.2/NEWS
branches/2.2/postgis/lwgeom_geos_prepared.c
branches/2.2/regress/tickets.sql
branches/2.2/regress/tickets_expected
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS 2016-02-24 16:35:19 UTC (rev 14686)
+++ branches/2.2/NEWS 2016-02-24 16:46:50 UTC (rev 14687)
@@ -9,6 +9,7 @@
- #3427, Update spatial_ref_sys to EPSG version 8.8
- #3433, ST_ClusterIntersecting incorrect for MultiPoints
- #3436, memory handling mistake in ptarray_clone_deep
+ - #3437, ST_Intersects incorrect for MultiPoints
- #3461, ST_GeomFromKML crashes Postgres when there are
innerBoundaryIs and no outerBoundaryIs
Modified: branches/2.2/postgis/lwgeom_geos_prepared.c
--- branches/2.2/postgis/lwgeom_geos_prepared.c 2016-02-24 16:35:19 UTC (rev 14686)
+++ branches/2.2/postgis/lwgeom_geos_prepared.c 2016-02-24 16:46:50 UTC (rev 14687)
@@ -316,7 +316,17 @@
lwpgerror("PrepGeomCacheBuilder asked to build new prepcache where one already exists.");
return LW_FAILURE;
+ * Avoid creating a PreparedPoint around a Point or a MultiPoint.
+ * Consider changing this behavior in the future if supported GEOS
+ * versions correctly handle prepared points and multipoints and
+ * provide a performance benefit.
+ * See https://trac.osgeo.org/postgis/ticket/3437
+ if (lwgeom_get_type(lwgeom) == POINTTYPE || lwgeom_get_type(lwgeom) == MULTIPOINTTYPE)
+ return LW_FAILURE;
prepcache->geom = LWGEOM2GEOS( lwgeom , 0);
if ( ! prepcache->geom ) return LW_FAILURE;
Modified: branches/2.2/regress/tickets.sql
--- branches/2.2/regress/tickets.sql 2016-02-24 16:35:19 UTC (rev 14686)
+++ branches/2.2/regress/tickets.sql 2016-02-24 16:46:50 UTC (rev 14687)
@@ -919,5 +919,20 @@
SELECT '#3375', ST_AsText(ST_RemoveRepeatedPoints('GEOMETRYCOLLECTION(POINT(0 -7))'::geometry, 1000));
+-- #3437
+WITH
+mp AS (SELECT ST_Collect(ST_MakePoint(-c, c*c)) AS geom FROM generate_series(1, 5) c),
+p AS (SELECT (ST_Dump(geom)).geom FROM mp)
+SELECT '#3437a' AS t, count(*) FROM mp INNER JOIN p ON ST_Intersects(mp.geom, p.geom)
+UNION ALL
+SELECT '#3437b' AS t, count(*) FROM mp INNER JOIN p ON ST_Contains(mp.geom, p.geom)
+UNION ALL
+SELECT '#3437c' AS t, count(*) FROM mp INNER JOIN p ON ST_ContainsProperly(mp.geom, p.geom)
+UNION ALL
+SELECT '#3437d' AS t, count(*) FROM mp INNER JOIN p ON ST_Covers(mp.geom, p.geom)
+UNION ALL
+SELECT '#3437e' AS t, count(*) FROM mp INNER JOIN p ON ST_Within(p.geom, mp.geom);
-- Clean up
DELETE FROM spatial_ref_sys;
Modified: branches/2.2/regress/tickets_expected
--- branches/2.2/regress/tickets_expected 2016-02-24 16:35:19 UTC (rev 14686)
+++ branches/2.2/regress/tickets_expected 2016-02-24 16:46:50 UTC (rev 14687)
@@ -280,3 +280,8 @@
#3367|POLYGON EMPTY
#3368|\x660001011fb98788d35ed6fbcdc831c580012b959f01469d8d0e9305ff8618ed08b1b607e302a614fe70bc4682b303b4379ab503a228eeb603e2138eb802900cc0b802ba04dab802b801a8840cb0229cca06f401c216f403a016ea05d0c301a8b301cc189226ac15ee27f811a029b40eac2ae00a902b8407c82b9e03d0e305801dfad3239504ce7e8d01e2f701f6019b04d1e2279bf901ff01
#3375|GEOMETRYCOLLECTION(POINT(0 -7))
+#3437a|5
+#3437b|5
+#3437c|5
+#3437d|5
+#3437e|5
