[postgis-tickets] [PostGIS] #3468: ST_GeogFromText should swap longitude when latitude crosses 90 deg
PostGIS trac at osgeo.org
Wed Feb 24 10:54:44 PST 2016
  Reporter:  tomvantilburg  |      Owner:  pramsey
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 2.2.2
 Component:  postgis        |    Version:  2.2.x
Resolution:                 |   Keywords:
Comment (by munderwood):
 I agree that the current behaviour poses a problem. Silently turning (10,
 91) into (-170, 89) would definitely be better than turning it into (10,
 89) as happens now.
 An even better option might be to throw an error, preventing the
 INSERT/UPDATE operation that is trying to set a latitude greater than 90.
 Best of all would be if there were a flag with which the DBA could make
 the choice of behaviour. Something like {{{SET out_of_range_latitudes TO
 wrap|reject|reflect}}}, for example. (I personally don't see any reason to
 have the "reflect" option for new databases, but it could be used in
 existing databases for backward compatibility of behaviour.)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3468#comment:2>
