[postgis-tickets] r14695 - #3469, support multipoint into to ST_MakeLine (Paul Norman)
Paul Ramsey
pramsey at cleverelephant.ca
Thu Feb 25 02:44:57 PST 2016
Author: pramsey
Date: 2016-02-25 02:44:57 -0800 (Thu, 25 Feb 2016)
New Revision: 14695
trunk/NEWS
trunk/doc/reference_constructor.xml
trunk/liblwgeom/lwline.c
trunk/postgis/lwgeom_functions_basic.c
trunk/regress/ctors.sql
trunk/regress/ctors_expected
Modified: trunk/NEWS
--- trunk/NEWS 2016-02-25 10:08:04 UTC (rev 14694)
+++ trunk/NEWS 2016-02-25 10:44:57 UTC (rev 14695)
@@ -14,6 +14,7 @@
- #3362 ST_ClusterDBSCAN (Dan Baston)
- #3428 ST_Points (Dan Baston)
- #3465 ST_ClusterKMeans (Paul Ramsey)
+ - #3469 ST_MakeLine with MULTIPOINTs (Paul Norman)
PostGIS 2.2.1
2016/01/06
Modified: trunk/doc/reference_constructor.xml
--- trunk/doc/reference_constructor.xml 2016-02-25 10:08:04 UTC (rev 14694)
+++ trunk/doc/reference_constructor.xml 2016-02-25 10:44:57 UTC (rev 14695)
@@ -1439,7 +1439,7 @@
<refnamediv>
<refname>ST_MakeLine</refname>
- <refpurpose>Creates a Linestring from point or line geometries.</refpurpose>
+ <refpurpose>Creates a Linestring from point, multipoint, or line geometries.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -1466,17 +1466,21 @@
<title>Description</title>
<para>ST_MakeLine comes in 3 forms: a spatial aggregate that takes
- rows of point-or-line geometries and returns a line string, a function that takes an array of point-or-lines, and a regular function that takes two point-or-line geometries. You
+ rows of point, multipoint, or line geometries and returns a line string, a
+ function that takes an array of point, multipoint, or line, and a regular
+ function that takes two point, multipoint, or line geometries. You
might want to use a subselect to order points before feeding them
to the aggregate version of this function.</para>
+ <para>Inputs other than point, multipoint, or lines are ignored.</para>
<para>
- When adding line components a common node is removed from the output.
+ When adding line components common nodes at the beginning of lines are removed from the output. Common nodes in point and multipoint inputs are not removed.
</para>
<para>&Z_support;</para>
<para>Availability: 1.4.0 - ST_MakeLine(geomarray) was introduced. ST_MakeLine aggregate functions was enhanced to handle more points faster.</para>
<para>Availability: 2.0.0 - Support for linestring input elements was introduced</para>
+ <para>Availability: 2.0.0 - Support for multipoint input elements was introduced</para>
</refsection>
<refsection>
Modified: trunk/liblwgeom/lwline.c
--- trunk/liblwgeom/lwline.c 2016-02-25 10:08:04 UTC (rev 14694)
+++ trunk/liblwgeom/lwline.c 2016-02-25 10:44:57 UTC (rev 14695)
@@ -165,12 +165,13 @@
LWLINE *
lwline_from_lwgeom_array(int srid, uint32_t ngeoms, LWGEOM **geoms)
- int i;
+ int i;
int hasz = LW_FALSE;
int hasm = LW_FALSE;
POINTARRAY *pa;
LWLINE *line;
POINT4D pt;
+ LWPOINTITERATOR* it;
* Find output dimensions, check integrity
@@ -182,7 +183,9 @@
if ( hasz && hasm ) break; /* Nothing more to learn! */
- /* ngeoms should be a guess about how many points we have in input */
+ * ngeoms should be a guess about how many points we have in input.
+ * It's an underestimate for lines and multipoints */
pa = ptarray_construct_empty(hasz, hasm, ngeoms);
for ( i=0; i < ngeoms; i++ )
@@ -198,8 +201,21 @@
else if ( g->type == LINETYPE )
+ * Append the new line points, de-duplicating against the previous points.
+ * Duplicated points internal to the linestring are untouched.
ptarray_append_ptarray(pa, ((LWLINE*)g)->points, -1);
+ else if ( g->type == MULTIPOINTTYPE )
+ it = lwpointiterator_create(g);
+ while(lwpointiterator_next(it, &pt))
+ ptarray_append_point(pa, &pt, LW_TRUE);
+ lwpointiterator_destroy(it);
else
ptarray_free(pa);
Modified: trunk/postgis/lwgeom_functions_basic.c
--- trunk/postgis/lwgeom_functions_basic.c 2016-02-25 10:08:04 UTC (rev 14694)
+++ trunk/postgis/lwgeom_functions_basic.c 2016-02-25 10:44:57 UTC (rev 14695)
@@ -1408,8 +1408,9 @@
geom = (GSERIALIZED *)DatumGetPointer(value);
- if ( gserialized_get_type(geom) != POINTTYPE &&
- gserialized_get_type(geom) != LINETYPE )
+ if ( gserialized_get_type(geom) != POINTTYPE &&
+ gserialized_get_type(geom) != LINETYPE &&
+ gserialized_get_type(geom) != MULTIPOINTTYPE)
continue;
Modified: trunk/regress/ctors.sql
--- trunk/regress/ctors.sql 2016-02-25 10:08:04 UTC (rev 14694)
+++ trunk/regress/ctors.sql 2016-02-25 10:44:57 UTC (rev 14695)
@@ -12,13 +12,24 @@
'LINESTRING(1 1, 10 0)'::geometry
+-- postgis-devel/2016-February/025634.html for repeated point background
select 'ST_MakeLine_agg1', ST_AsText(ST_MakeLine(g)) from (
values ('POINT(0 0)'),
('LINESTRING(1 1, 10 0)'),
('LINESTRING(10 0, 20 20)'),
- ('POINT(40 4)')
+ ('POINT(40 4)'),
+ ('POINT(40 4)'),
+ ('POINT(40 5)'),
+ ('MULTIPOINT(40 5, 40 6, 40 6, 40 7)'),
+ ('LINESTRING(40 7, 40 8)')
) as foo(g);
+select 'ST_MakeLine_agg2', ST_AsText(ST_MakeLine(g)) from (
+ values ('POINT(0 0)'),
+ ('LINESTRING(0 0, 1 0)'),
+ ('POINT(1 0)')
+) as foo(g);
-- postgis-users/2006-July/012788.html
select ST_makebox2d('SRID=3;POINT(0 0)', 'SRID=3;POINT(1 1)');
select ST_makebox2d('POINT(0 0)', 'SRID=3;POINT(1 1)');
Modified: trunk/regress/ctors_expected
--- trunk/regress/ctors_expected 2016-02-25 10:08:04 UTC (rev 14694)
+++ trunk/regress/ctors_expected 2016-02-25 10:44:57 UTC (rev 14695)
@@ -3,7 +3,8 @@
SRID=3;LINESTRING(0 0,1 1)
ERROR: Operation on mixed SRID geometries
ST_MakeLine1|LINESTRING(0 0,1 1,10 0)
-ST_MakeLine_agg1|LINESTRING(0 0,1 1,10 0,20 20,40 4)
+ST_MakeLine_agg1|LINESTRING(0 0,1 1,10 0,20 20,40 4,40 4,40 5,40 5,40 6,40 6,40 7,40 8)
+ST_MakeLine_agg2|LINESTRING(0 0,1 0,1 0)
BOX(0 0,1 1)
BOX3D(0 0 0,1 1 0)
