[postgis-tickets] [PostGIS] #3429: upgrade from 2.1.3 to 2.2+ enters infinite loop
PostGIS trac at osgeo.org
Thu Feb 25 02:50:53 PST 2016
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 2.2.2
 Component:  build/upgrade/install  |    Version:  2.2.x
Resolution:                         |   Keywords:
Comment (by pramsey):
 Stripping it down to the minimum amount of SQL, no upgrade required,
 assuming you have done `make install` on both postgis 2.1.8 and svn trunk:
 DROP DATABASE IF EXISTS pg21;
 CREATE DATABASE pg21;
 \c pg21
 SELECT postgis_raster_lib_version();
 CREATE EXTENSION postgis VERSION '2.1.8';
 CREATE OR REPLACE FUNCTION bytea(raster)
     RETURNS bytea
     AS '$libdir/rtpostgis-2.3', 'RASTER_to_bytea'
     LANGUAGE 'c' IMMUTABLE STRICT;
 Basically get the old library loaded, then bring in the new one, which
 causes the _PG_init() hook to run. Then things fall apart on Ubuntu (but
 not on OSX)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3429#comment:22>
