[postgis-tickets] [PostGIS] #3429: upgrade from 2.1.3 to 2.2+ enters infinite loop
PostGIS trac at osgeo.org
Thu Feb 25 09:57:03 PST 2016
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 2.2.2
 Component:  build/upgrade/install  |    Version:  2.2.x
Resolution:                         |   Keywords:
Comment (by pramsey):
 At r14694 I have changed svn/2.3 to do right-away setting of pgsql memory
 management/messaging, rather than the old complex lazy loading scheme. The
 ./postgis side has been doing this since forever, so moving raster to do
 it too is fine, IMO. This was because we were seeing the update process
 hang at the first call to an allocator. The 2.2/2.1 versions also still
 have this pattern, so potentially removing it from them as well might be
 required to be 100% certain that it is not the source of our pain.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3429#comment:23>
