[postgis-tickets] [PostGIS] #3429: upgrade from 2.1.3 to 2.2+ enters infinite loop
trac at osgeo.org
Thu Feb 25 09:59:59 PST 2016
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.2
Component: build/upgrade/install | Version: 2.2.x
Resolution: | Keywords:
Comment (by pramsey):
The current problem seems to be strongly associated with the
`rtpg_assignHookGDALEnabledDrivers` function. In 2.0 to 2.1 it was called
in `_PG_init()` directly to read the environment variables and set up GDAL
drivers the user wants.
If you remove calls to `rtpg_assignHookGDALEnabledDrivers` in 2.3/svn, you
can get a clean upgrade from 2.1, no hang. If you change the call to
`rtpg_assignHookGDALEnabledDrivers` in 2.3/svn from a callback in the GUC
setting function to a direct call in `_PG_init()` you can **also** get a
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3429#comment:24>
