[postgis-tickets] r14705 - Expunge rt_init_allocators (#3429)
Paul Ramsey pramsey at cleverelephant.ca
Fri Feb 26 03:37:39 PST 2016
Author: pramsey
Date: 2016-02-26 03:37:39 -0800 (Fri, 26 Feb 2016)
New Revision: 14705
   branches/2.1/raster/loader/raster2pgsql.c
   branches/2.1/raster/rt_core/rt_api.c
   branches/2.1/raster/rt_core/rt_api.h
   branches/2.1/raster/rt_pg/rt_pg.c
   branches/2.1/raster/test/cunit/cu_tester.c
Modified: branches/2.1/raster/loader/raster2pgsql.c
--- branches/2.1/raster/loader/raster2pgsql.c	2016-02-26 11:19:07 UTC (rev 14704)
+++ branches/2.1/raster/loader/raster2pgsql.c	2016-02-26 11:37:39 UTC (rev 14705)
@@ -61,7 +61,8 @@
 	va_end(ap);
-void rt_init_allocators(void) {
+static void
+rt_init_allocators(void) {
 	rt_set_handlers(
 		default_rt_allocator,
 		default_rt_reallocator,
@@ -2300,6 +2301,9 @@
 	textdomain (PACKAGE);
 #endif
+	/* Set up memory allocators */
+	rt_init_allocators();
 	/* no args, show usage */
 	if (argc == 1) {
 		usage();
Modified: branches/2.1/raster/rt_core/rt_api.c
--- branches/2.1/raster/rt_core/rt_api.c	2016-02-26 11:19:07 UTC (rev 14704)
+++ branches/2.1/raster/rt_core/rt_api.c	2016-02-26 11:37:39 UTC (rev 14705)
@@ -731,14 +731,6 @@
 /*- rt_context -------------------------------------------------------*/
-/* Functions definitions */
-void * init_rt_allocator(size_t size);
-void * init_rt_reallocator(void * mem, size_t size);
-void init_rt_deallocator(void * mem);
-void init_rt_errorreporter(const char * fmt, va_list ap);
-void init_rt_warnreporter(const char * fmt, va_list ap);
-void init_rt_inforeporter(const char * fmt, va_list ap);
  * Default allocators
@@ -819,18 +811,17 @@
 /* Static variable, to be used for all rt_core functions */
 static struct rt_context_t ctx_t = {
-    .alloc = init_rt_allocator,
-    .realloc = init_rt_reallocator,
-    .dealloc = init_rt_deallocator,
-    .err = init_rt_errorreporter,
-    .warn = init_rt_warnreporter,
-    .info = init_rt_inforeporter
+    .alloc = default_rt_allocator,
+    .realloc = default_rt_reallocator,
+    .dealloc = default_rt_deallocator,
+    .err = default_rt_error_handler,
+    .warn = default_rt_warning_handler,
+    .info = default_rt_info_handler
- * This function is normally called by rt_init_allocators when no special memory
- * management is needed. Useful in raster core testing and in the (future)
+ * Useful in raster core testing and in the (future)
  * loader, when we need to use raster core functions but we don't have
  * PostgreSQL backend behind. We must take care of memory by ourselves in those
  * situations
@@ -848,7 +839,7 @@
- * This function is called by rt_init_allocators when the PostgreSQL backend is
+ * This function is called when the PostgreSQL backend is
  * taking care of the memory and we want to use palloc family
 void
@@ -868,67 +859,6 @@
- * Initialisation allocators
- * These are used the first time any of the allocators are called to enable
- * executables/libraries that link into raster to be able to set up their own
- * allocators. This is mainly useful for older PostgreSQL versions that don't
- * have functions that are called upon startup.
-void *
-init_rt_allocator(size_t size)
-    rt_init_allocators();
-    return ctx_t.alloc(size);
-void
-init_rt_deallocator(void *mem)
-    ctx_t.dealloc(mem);
-void *
-init_rt_reallocator(void *mem, size_t size)
-    return ctx_t.realloc(mem, size);
-void
-init_rt_inforeporter(const char *fmt, va_list ap)
-    (*ctx_t.info)(fmt, ap);
-void
-init_rt_warnreporter(const char *fmt, va_list ap)
-    (*ctx_t.warn)(fmt, ap);
-void
-init_rt_errorreporter(const char *fmt, va_list ap)
-    (*ctx_t.err)(fmt, ap);
  * Raster core memory management functions.
  * They use the functions defined by the caller.
Modified: branches/2.1/raster/rt_core/rt_api.h
--- branches/2.1/raster/rt_core/rt_api.h	2016-02-26 11:19:07 UTC (rev 14704)
+++ branches/2.1/raster/rt_core/rt_api.h	2016-02-26 11:37:39 UTC (rev 14705)
@@ -122,9 +122,8 @@
  * of non-PostGIS applications using rt_core.
  * Programs using this library should set up the default memory managers and error
- * handlers by implementing an rt_init_allocators() function, which can be as
- * a wrapper around the rt_install_default_allocators() function if you want
- * no special handling for memory management and error reporting.
+ * handlers by calling rt_set_handlers() or the rt_install_default_allocators()
+ * function if you want no special handling for memory management and error reporting.
@@ -219,27 +218,12 @@
 typedef void  (*rt_deallocator)(void *mem);
 typedef void  (*rt_message_handler)(const char* string, va_list ap);
- * Functions that must be implemented for the raster core function's caller
- * (for example: rt_pg functions, test functions, future loader/exporter)
- * Supply the memory management and error handling functions you want your
- * application to use
-extern void rt_init_allocators(void);
  * Functions that may be used by the raster core function's caller
  * Apply the default memory management (malloc() and free()) and error handlers.
- * Called inside rt_init_allocators() generally.
 extern void rt_install_default_allocators(void);
Modified: branches/2.1/raster/rt_pg/rt_pg.c
--- branches/2.1/raster/rt_pg/rt_pg.c	2016-02-26 11:19:07 UTC (rev 14704)
+++ branches/2.1/raster/rt_pg/rt_pg.c	2016-02-26 11:37:39 UTC (rev 14705)
@@ -95,6 +95,78 @@
 #define ENV_POSTGIS_GDAL_ENABLED_DRIVERS "POSTGIS_GDAL_ENABLED_DRIVERS"
 #define ENV_POSTGIS_ENABLE_OUTDB_RASTERS "POSTGIS_ENABLE_OUTDB_RASTERS"
+/*  Memory allocation / error reporting hooks                       */
+static void *
+rt_pg_alloc(size_t size)
+    void * result;
+    POSTGIS_RT_DEBUGF(5, "rt_pgalloc(%ld) called", (long int) size);
+    result = palloc(size);
+    return result;
+static void *
+rt_pg_realloc(void *mem, size_t size)
+    void * result;
+    POSTGIS_RT_DEBUGF(5, "rt_pg_realloc(%ld) called", (long int) size);
+    if (mem)
+        result = repalloc(mem, size);
+    else
+    return result;
+static void
+rt_pg_free(void *ptr)
+    POSTGIS_RT_DEBUG(5, "rt_pfree called");
+    pfree(ptr);
+static void
+rt_pg_error(const char *fmt, va_list ap)
+#define ERRMSG_MAXLEN 256
+    char errmsg[ERRMSG_MAXLEN+1];
+    vsnprintf (errmsg, ERRMSG_MAXLEN, fmt, ap);
+    errmsg[ERRMSG_MAXLEN]='\0';
+    ereport(ERROR, (errmsg_internal("%s", errmsg)));
+static void
+rt_pg_notice(const char *fmt, va_list ap)
+    char *msg;
+     * This is a GNU extension.
+     * Dunno how to handle errors here.
+    if (!lw_vasprintf (&msg, fmt, ap))
+        va_end (ap);
+        return;
+    ereport(NOTICE, (errmsg_internal("%s", msg)));
+    free(msg);
 /* rtpg_assignHookGDALEnabledDrivers() should only be called by _PG_init */
 static void
 rtpg_assignHookGDALEnabledDrivers() {
@@ -261,6 +333,12 @@
 void _PG_init(void) {
 	char *env_postgis_enable_outdb_rasters = NULL;
+	/* Install liblwgeom handlers */
+	pg_install_lwgeom_handlers();
+	/* Install rt_api handlers */
+	rt_set_handlers(rt_pg_alloc, rt_pg_realloc, rt_pg_free, rt_pg_error, rt_pg_notice, rt_pg_notice);
 	 * use POSTGIS_ENABLE_OUTDB_RASTERS to enable access to out-db rasters
@@ -290,10 +368,6 @@
 	rtpg_assignHookGDALEnabledDrivers();
-	/* Install liblwgeom handlers */
-	pg_install_lwgeom_handlers();
-    /* TODO: Install raster callbacks (see rt_init_allocators) */
@@ -19411,83 +19485,3 @@
 	PG_RETURN_POINTER(pgrtn);
-/*  Memory allocation / error reporting hooks                       */
-/*  TODO: reuse the ones in libpgcommon ?                           */
-static void *
-rt_pg_alloc(size_t size)
-    void * result;
-    POSTGIS_RT_DEBUGF(5, "rt_pgalloc(%ld) called", (long int) size);
-    result = palloc(size);
-    return result;
-static void *
-rt_pg_realloc(void *mem, size_t size)
-    void * result;
-    POSTGIS_RT_DEBUGF(5, "rt_pg_realloc(%ld) called", (long int) size);
-    if (mem)
-        result = repalloc(mem, size);
-    else
-    return result;
-static void
-rt_pg_free(void *ptr)
-    POSTGIS_RT_DEBUG(5, "rt_pfree called");
-    pfree(ptr);
-static void
-rt_pg_error(const char *fmt, va_list ap)
-#define ERRMSG_MAXLEN 256
-    char errmsg[ERRMSG_MAXLEN+1];
-    vsnprintf (errmsg, ERRMSG_MAXLEN, fmt, ap);
-    errmsg[ERRMSG_MAXLEN]='\0';
-    ereport(ERROR, (errmsg_internal("%s", errmsg)));
-static void
-rt_pg_notice(const char *fmt, va_list ap)
-    char *msg;
-     * This is a GNU extension.
-     * Dunno how to handle errors here.
-    if (!lw_vasprintf (&msg, fmt, ap))
-        va_end (ap);
-        return;
-    ereport(NOTICE, (errmsg_internal("%s", msg)));
-    free(msg);
-void
-rt_init_allocators(void)
-    /* raster callback - install raster handlers */
-    rt_set_handlers(rt_pg_alloc, rt_pg_realloc, rt_pg_free, rt_pg_error,
-            rt_pg_notice, rt_pg_notice);
Modified: branches/2.1/raster/test/cunit/cu_tester.c
--- branches/2.1/raster/test/cunit/cu_tester.c	2016-02-26 11:19:07 UTC (rev 14704)
+++ branches/2.1/raster/test/cunit/cu_tester.c	2016-02-26 11:37:39 UTC (rev 14705)
@@ -84,6 +84,15 @@
 	/* install the custom error handler */
 	lwgeom_set_handlers(0, 0, 0, cu_error_reporter, 0);
+	rt_set_handlers(
+		default_rt_allocator,
+		default_rt_reallocator,
+		default_rt_deallocator,
+		cu_error_reporter,
+		default_rt_info_handler,
+		default_rt_warning_handler
 	/* initialize the CUnit test registry */
 	if (CUE_SUCCESS != CU_initialize_registry())
@@ -262,13 +271,3 @@
 	return band;
-	rt_set_handlers(
-		default_rt_allocator,
-		default_rt_reallocator,
-		default_rt_deallocator,
-		cu_error_reporter,
-		default_rt_info_handler,
-		default_rt_warning_handler
