[postgis-tickets] r14706 - Segmentize geography using equal length segments, from
Paul Ramsey
pramsey at cleverelephant.ca
Fri Feb 26 06:25:04 PST 2016
Author: pramsey
Date: 2016-02-26 06:25:03 -0800 (Fri, 26 Feb 2016)
New Revision: 14706
trunk/liblwgeom/lwgeodetic.c
trunk/regress/geography.sql
trunk/regress/geography_expected
trunk/regress/tickets_expected
https://github.com/postgis/postgis/pull/90
Hugo Mercier, @mhugo
Modified: trunk/liblwgeom/lwgeodetic.c
--- trunk/liblwgeom/lwgeodetic.c 2016-02-26 11:37:39 UTC (rev 14705)
+++ trunk/liblwgeom/lwgeodetic.c 2016-02-26 14:25:03 UTC (rev 14706)
@@ -1550,7 +1550,6 @@
int hasm = ptarray_has_m(pa_in);
int pa_in_offset = 0; /* input point offset */
POINT4D p1, p2, p;
- POINT3D q1, q2, q, qn;
GEOGRAPHIC_POINT g1, g2, g;
double d;
@@ -1592,32 +1591,21 @@
int nsegs = 1 + d / max_seg_length;
int i;
- double dx, dy, dz, dzz = 0, dmm = 0;
- geog2cart(&g1, &q1);
- geog2cart(&g2, &q2);
- dx = (q2.x - q1.x) / nsegs;
- dy = (q2.y - q1.y) / nsegs;
- dz = (q2.z - q1.z) / nsegs;
+ double dx, dy, dzz = 0, dmm = 0;
+ g = g1;
+ dx = (g2.lat - g1.lat) / nsegs;
+ dy = (g2.lon - g1.lon) / nsegs;
/* The independent Z/M values on the ptarray */
if ( hasz ) dzz = (p2.z - p1.z) / nsegs;
if ( hasm ) dmm = (p2.m - p1.m) / nsegs;
- q = q1;
p = p1;
for ( i = 0; i < nsegs - 1; i++ )
/* Move one increment forwards */
- q.x += dx; q.y += dy; q.z += dz;
- qn = q;
- normalize(&qn);
- /* Back to spherical coordinates */
- cart2geog(&qn, &g);
- /* Back to lon/lat */
+ g.lat += dx;
+ g.lon += dy;
p.x = rad2deg(g.lon);
p.y = rad2deg(g.lat);
if ( hasz )
Modified: trunk/regress/geography.sql
--- trunk/regress/geography.sql 2016-02-26 11:37:39 UTC (rev 14705)
+++ trunk/regress/geography.sql 2016-02-26 14:25:03 UTC (rev 14706)
@@ -107,6 +107,13 @@
ORDER BY distance_t;
DROP TABLE dwithgeogbug;
+-- Test segmentize on geography
+-- Check that the maximum sphere distance over all the segments is lesser than the max distance used for segmentize
+WITH
+seg as (select ST_Segmentize('LINESTRING(0 0 10,0 90 20)'::geography, 50000)::geometry as geom),
+dumped as (SELECT (st_dumppoints(geom)).path[1] as id, (st_dumppoints(geom)).geom from seg)
+SELECT 'segmentize_geography', max(st_distance(d1.geom::geography, d2.geom::geography, false))::int FROM dumped as d1, dumped as d2 where d2.id = d1.id + 1;
-- Clean up spatial_ref_sys
DELETE FROM spatial_ref_sys WHERE srid IN (4269,4326);
\ No newline at end of file
Modified: trunk/regress/geography_expected
--- trunk/regress/geography_expected 2016-02-26 11:37:39 UTC (rev 14705)
+++ trunk/regress/geography_expected 2016-02-26 14:25:03 UTC (rev 14706)
@@ -27,3 +27,4 @@
#2422|1|1609|t|t|1400.230|1396.816|1400.230|1400.230
#2422|1|1600|t|t|1400.230|1396.816|1400.230|1400.230
#2422|1|1068|f|f|1400.230|1396.816|1400.230|1400.230
+segmentize_geography|49789
Modified: trunk/regress/tickets_expected
--- trunk/regress/tickets_expected 2016-02-26 11:37:39 UTC (rev 14705)
+++ trunk/regress/tickets_expected 2016-02-26 14:25:03 UTC (rev 14706)
@@ -236,7 +236,7 @@
#2110.1|f
#2110.2|t
#2110.3|t
-#2145|6792004
+#2145|6792007
#2232|M 0 0 l 0 0 1 0 0 0 1 0 0 0
#2307|MULTIPOLYGON(((-41.1932 -7.3257,-41.1616 -7.3257,-41.1569 -7.3257,-41.1569 -7.3483,-41.1932 -7.3483,-41.1932 -7.3257),(-41.1616 -7.3257,-41.1879 -7.3257,-41.1879 -7.3425,-41.1616 -7.3425,-41.1616 -7.3257)))
#2409|GeometryCollection[B] with 2 elements
