[postgis-tickets] r14711 - use a new arg identifier winset for window functions.
Regina Obe
lr at pcorp.us
Sat Feb 27 00:05:34 PST 2016
Author: robe
Date: 2016-02-27 00:05:34 -0800 (Sat, 27 Feb 2016)
New Revision: 14711
trunk/doc/reference_measure.xml
trunk/doc/template.xml
trunk/doc/xsl/postgis_aggs_mm.xml.xsl
trunk/doc/xsl/postgis_comments.sql.xsl
Update window functions to be flagged as taking input geometry winset
Update templste.xml (to instruct how to flag window and aggregate functions)
Update the comments generation to handle the new geometry winset type arg
Closes #3474
Mark ST_ClusterWithin and ST_ClusterIntersecting
as taking geometry set (so flagged as aggregates)
Closes #3476
Modified: trunk/doc/reference_measure.xml
--- trunk/doc/reference_measure.xml 2016-02-27 07:59:53 UTC (rev 14710)
+++ trunk/doc/reference_measure.xml 2016-02-27 08:05:34 UTC (rev 14711)
@@ -1062,7 +1062,7 @@
<funcprototype>
<funcdef>integer <function>ST_ClusterDBSCAN</function></funcdef>
- <paramdef><type>geometry </type>
+ <paramdef><type>geometry winset </type>
<parameter>geom</parameter></paramdef>
<paramdef><type>float8 </type>
@@ -1130,7 +1130,7 @@
<funcsynopsis>
<funcprototype>
<funcdef>geometry[] <function>ST_ClusterIntersecting</function></funcdef>
- <paramdef><type>geometry </type> <parameter>g</parameter></paramdef>
+ <paramdef><type>geometry set</type> <parameter>g</parameter></paramdef>
</funcprototype>
</funcsynopsis>
</refsynopsisdiv>
@@ -1187,7 +1187,7 @@
<funcprototype>
<funcdef>integer <function>ST_ClusterKMeans</function></funcdef>
<paramdef><type>integer </type>
@@ -1235,7 +1235,7 @@
<funcsynopsis>
<funcprototype>
<funcdef>geometry[] <function>ST_ClusterWithin</function></funcdef>
+ <paramdef><type>geometry set </type> <parameter>g</parameter></paramdef>
<paramdef><type>float8 </type> <parameter>distance</parameter></paramdef>
</funcprototype>
</funcsynopsis>
Modified: trunk/doc/template.xml
--- trunk/doc/template.xml 2016-02-27 07:59:53 UTC (rev 14710)
+++ trunk/doc/template.xml 2016-02-27 08:05:34 UTC (rev 14711)
@@ -14,7 +14,7 @@
<paramdef><type>geometry </type> <parameter>g2</parameter></paramdef>
</funcprototype>
- <!-- an optional second method prototype -->
+ <!-- an optional second method prototype with default args -->
<funcprototype>
<funcdef>boolean <function>ST_MyMethod</function></funcdef>
<paramdef><type>geometry </type> <parameter>g1</parameter></paramdef>
@@ -23,6 +23,22 @@
<paramdef choice="opt"><type>varchar </type> <parameter>myparam=the_default_value</parameter></paramdef>
</funcprototype>
+ <!-- example of a spatial aggregate prototype -->
+ <!-- If your function is an aggregate, the input for the
+ set part eg. set of geometries, should be of type geometry set/geometry set instead of geometry/geography -->
+ <funcprototype>
+ <funcdef>geometry <function>ST_MyMethod</function></funcdef>
+ <paramdef><type>geometry set </type> <parameter>g1</parameter></paramdef>
+ </funcprototype>
+ <!-- example of a spatial window function prototype -->
+ <!-- If your function is window function, the input for the
+ set part (the input to the window) eg. set of geometries, should be of type geometry winset/geometry winset instead of geometry/geography -->
+ <funcprototype>
+ <paramdef><type>geometry winset </type> <parameter>g1</parameter></paramdef>
+ </funcprototype>
</funcsynopsis>
</refsynopsisdiv>
Modified: trunk/doc/xsl/postgis_aggs_mm.xml.xsl
--- trunk/doc/xsl/postgis_aggs_mm.xml.xsl 2016-02-27 07:59:53 UTC (rev 14710)
+++ trunk/doc/xsl/postgis_aggs_mm.xml.xsl 2016-02-27 08:05:34 UTC (rev 14711)
@@ -44,7 +44,36 @@
</xsl:for-each>
</itemizedlist>
</sect1>
+ <sect1 id="PostGIS_Window_Functions">
+ <title>PostGIS Window Functions</title>
+ <para>The functions given below are spatial window functions provided with PostGIS that can be used just like any other sql window function such as row_numer(), lead(), lag(). All these require an SQL OVER() clause.</para>
+ <itemizedlist>
+ <!-- Pull out the purpose section for each ref entry and strip whitespace and put in a variable to be tagged unto each function comment -->
+ <xsl:for-each select='//refentry'>
+ <xsl:sort select="refnamediv/refname"/>
+ <xsl:variable name='comment'>
+ <xsl:value-of select="normalize-space(translate(translate(refnamediv/refpurpose,'
+ </xsl:variable>
+ <xsl:variable name="refid">
+ <xsl:value-of select="@id" />
+ </xsl:variable>
+ <xsl:variable name="refname">
+ <xsl:value-of select="refnamediv/refname" />
+ </xsl:variable>
+ <!-- For each function prototype if it takes a geometry set then catalog it as an aggregate function -->
+ <xsl:for-each select="refsynopsisdiv/funcsynopsis/funcprototype">
+ <xsl:choose>
+ <xsl:when test="contains(paramdef/type,' winset')">
+ <listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refname" /></link> - <xsl:value-of select="$comment" /></simpara></listitem>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:for-each>
+ </xsl:for-each>
+ </itemizedlist>
+ </sect1>
<sect1 id="PostGIS_SQLMM_Functions">
<title>PostGIS SQL-MM Compliant Functions</title>
<para>The functions given below are PostGIS functions that conform to the SQL/MM 3 standard</para>
Modified: trunk/doc/xsl/postgis_comments.sql.xsl
--- trunk/doc/xsl/postgis_comments.sql.xsl 2016-02-27 07:59:53 UTC (rev 14710)
+++ trunk/doc/xsl/postgis_comments.sql.xsl 2016-02-27 08:05:34 UTC (rev 14711)
@@ -37,10 +37,11 @@
</xsl:choose>
<!-- For each function prototype generate the DDL comment statement
If its input is a geometry set - we know it is an aggregate function rather than a regular function
+ If its input is a geometry winset we know it is a window function but comment signature of those are the same just have to strip off the winset
Do not output OUT params since they define output rather than act as input and do not put a comma after argument just before an OUT parameter -->
COMMENT ON <xsl:choose><xsl:when test="contains(paramdef/type,'geometry set')">AGGREGATE</xsl:when><xsl:otherwise>FUNCTION</xsl:otherwise></xsl:choose><xsl:text> </xsl:text> <xsl:value-of select="funcdef/function" />(<xsl:for-each select="paramdef"><xsl:choose><xsl:when test="count(parameter) > 0">
-<xsl:choose><xsl:when test="contains(parameter,'OUT')"></xsl:when><xsl:when test="contains(type,'geometry set')">geometry</xsl:when><xsl:otherwise><xsl:value-of select="type" /></xsl:otherwise></xsl:choose><xsl:if test="position()<last() and not(contains(parameter,'OUT')) and not(contains(following-sibling::paramdef[1],'OUT'))"><xsl:text>, </xsl:text></xsl:if></xsl:when>
+<xsl:choose><xsl:when test="contains(parameter,'OUT')"></xsl:when><xsl:when test="contains(type,'geometry set')">geometry</xsl:when><xsl:when test="contains(type,'geometry winset')">geometry</xsl:when><xsl:when test="contains(type,'geography winset')">geography</xsl:when><xsl:otherwise><xsl:value-of select="type" /></xsl:otherwise></xsl:choose><xsl:if test="position()<last() and not(contains(parameter,'OUT')) and not(contains(following-sibling::paramdef[1],'OUT'))"><xsl:text>, </xsl:text></xsl:if></xsl:when>
</xsl:choose></xsl:for-each>) IS '<xsl:call-template name="listparams"><xsl:with-param name="func" select="." /></xsl:call-template> <xsl:value-of select='$comment' />';
</xsl:for-each>
</xsl:for-each>
